Question about Olevia LT27HVX 27 in. LCD Television
TV Tuner How do I add channels to the tuner? I was in the favorites menu but it wont let me do anything.
    President:
  • 1,284 Answers
You need to go to the setup and let the TV autoprogram channels into its memory. This is a benifit in two ways because for one the set does the programming for you but, at the same time will activly search for digital channels on your cable system or antenna which ever you are using.
Posted on Feb 08, 2008
How do i select the channel menu
Many times the re-scan tune option goes away if you've selected an input on the TV other than the "tuner", "Antenna" or similar (ie: AV1, HDMI1, Sat, Cable, etc.do not make use of your TV's internal tuner).
Make sure you select an input on your TV, ( tuner, etc.) that will use the tuner and have an antenna or non-digital Cable TV coaxial cable connected. Then attempt to scan again.
Dec 15, 2014 | Televison & Video
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
My rca hd52w58 on autoscan will only find 4hannels MY Visio fines 38 suspect digital tuner any suggeationas?
Could be a tuner but a simple way to find out is DIRECT ENTER with the remote (numbers) a channel and hit enter---if it goes to missing channel you can manually in the menu with the remote ADD each missing channel one at a time--tedious but will rule the tuner out.
Almost every set made is able to add or delete channels one at a time.
Apr 15, 2012 | RCA HD52W59 HDTV Projection Television
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
How do I do a channel scan?
Press Menu on the TV (second button from the left) or the remote. Use the Vol + / Vol - buttons to highlight Tuner, only available when the input is the TV (press TV/AV to get to the correct source) mode. Press Ch+/Ch- to highlight AutoProgram and then Vol+ to start the search for channels. The TV will show Tuning Finished when done and then go to the lowest channel found. If you want to add or remove stations, tune to the desired channel, then press Menu, and highlight Tuner, Ch+/Ch- to highlight Add/Erase, then Vol+/Vol- to set Add or Erase. Press TV/AV/Exit to get out of the menu.
I hope this helps.
Jul 28, 2010 | Philips Magnavox 27MS343S 27" TV
Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
May 24, 2009 | Philips 26PF5320 26 in. LCD Television
We have a TV in our 2007 5th Wheel RV unit and we need to know if it's a digital TV. We did not receive any paperwork for the television. The model number is TVM1916F or possibly TVM1916E. Could you let...
This unit has a 181 channel tuner and while I can't find anything that states it has a digital tuner, it sounds like it does. The easiest way to find out is to check the setup menu. If it has a digital tuner, it should give you the option to autoprogram the digital channels.
Hope this helps,
Dan
Sep 04, 2008 | Televison & Video
Can I get more channels?
go to the menu and navigate to auto-prog(ram)
Feb 24, 2008 | Sanyo DS31520 31" TV
RCA F27664 27" TV Problem: HELP
Intermittent loss of lower frequency channels ie Ch:36, higher channels ok
Dry joints in UHF tuner, resolder the PCB to casing earth connections inside tuner
Channel reception lost if tuner socket moved
Dry joints on IC522, IC521 and IC541 (located in the big heatsink about middle of the main pcb)
Nov 24, 2007 | RCA F27664 27" TV
Olevia LT27HVX 27 in. LCD Television Logo
185 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
