Prints blank pages
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1.
Load a few sheets of plain paper in the sheet feeder.
2.
Turn off the Epson Stylus NX100 Series.
3.
Hold down the Stop button as you press the On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the On light begins to flash, then release the buttons.
1.
2.
3.
Hold down the Stop button as you Does not print - nx100_tx100_ug.1.96.2.jpgads/images/nx100_tx100_ug.1.96.2.jpg" alt="nx100_tx100_ug.1.96.2.jpg" class="h_mi" /> On button to turn the Epson Stylus NX100 Series back on. Hold dDoes not print - nx100_tx100_ug.1.96.3.jpge On light begins to flash, then release the buttons.
1.
2.
Hold down the button as you press the On button toDoes not print - nx100_tx100_ug.1.96.3.jpg100 Series back on. Hold down both buttons until the On light begins to flash, then release the buttons.
4.
Check thDoes not print - nx100_tx100_ug.1.96.5.jpgck pattern that prints to see if there are gaps in the lines.
5.
If there are no gaps, the print head is clean and you can continue printing.
If there are gaps or the pattern is faint, clean the print head.
If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.)
Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
1.
2.
3.
1.
2.
3.
1.
2.
3.
4.
Check the nozzle check pattern that prints to see if there are gaps in the lines.
5.
