Question about InFocus LP70+ Multimedia Projector
LP70+ Not working with Locked Down Machine
Are admin rights required to use an LP70+? I have users who have a locked down image and when they try to use the projector nothing happens when it is plugged in.
  • 2,237 Answers
It is not locked down. if there are no leds lit, the power supply is bad.
Posted on Sep 03, 2009
Web image monitor
User name admin
No password if this does not work, then you are locked out, sorry.-Carl
Mar 26, 2014 | Ricoh Rocoh Aficio MP C2000 C2500 C3000...
Tip
Install .msi files for plain user account
Many corporate environments are locked down, all users do not have rights to install applications by themselves. This helps reduce virus infections and spreading. <br /><br />But as IT staff, we need to help these users install applications that will help them do their job. Many new applications are in .msi format which means you can not hold shift and right click on the .msi file to Runas Administrator or elevated privileges.<br /><br />This tip requires you to know some basic MS-DOS command line syntax. But first you need to start a command prompt with the elevated rights.<br /><br /> Step 1, Open command prompt Step 2, Type: Runas /user:administrator "cmd" (enter administrator password) Step 3, change directory to location of .msi install file (simple DOS commands) Step 4, Run .msi file via command line, this will start theinstall via local administrator account. Complete installation Step 5, close admin command prompt screen.
on Mar 08, 2011 | Computers & Internet
Factory reset advent computer
You mean you want to reset in safe mode?
Well, here is how to use safe mode reset windows password :
Step 1. Press F8 when your Windows is booting. You will come to the Advanced Boot Options.
Step 2. Select Safe Mode with Command Prompt and press Enter.
Step 3. Enter safe mode with an available admin account. And a command prompt will appear.
Step 4. Type net user in command prompt and press Enter. It will show you all accounts on the Windows .
Step 5. Type net user Amber123 (Amber is the locked admin account's name and 123 is the new password. This depends on the setting of your computer) and press Enter. Now you have successfully created a new password on the locked admin account.
Step 6. Type shut down -r -t 00 and press Enter.
Step 7. The computer will reboot automatically and then you can log on Windows
Resource from: http://www.windowspasswordreset.net/article/windows-7-login-password-recovery.html
Jul 11, 2012 | Advent Computers & Internet
Door locked no power
If the machine didnt finish the cycle due to the pump being clogged the door will remained locked also if the lock mechanism went bad, the machine will stay locked. Remove the top of the machine by taking the screws from the top back out. Once removed look down the right hand side and you'll see the lock mechanism, usually with a plastic tab you pull to manually release the lock. On some machines it maybe be required and sometimes easier to remove the bottom kickplate and access the lock assembly from there
May 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
The door is locked and wont open
May 08, 2012 | Frigidaire ATF6000ES Front Load Washer
How do i get to the bad door latch?
Apr 25, 2012 | Kenmore Front Load Washer
I need to delete the main user so i can get plugins and downloads.
Chances are you only need to make your current user an Admin user.
Try the following:
Hold down on the Apple in the upper left-hand corner of your screen.
1. Select System Preferences
2. Click on the Accounts icon
a. If the paddle lock is closed click on it to open it (This requires the admin user name and password)
3. Click your User name (if underneath your name it shows Standard)
4. Then click in the "Allow user to administer this computer" if the box is empty.
If that does not work give a little more detail about what you are trying to do.
Oct 21, 2010 | Apple Mac OS X 10.4
Inspiron 1525 keyboard/touchpad locked.
Press ctrl alt del together then try to enter your password. If it doesn't work. restart your computer by holding down the power button for 10 seconds or until the computer turns off. Restart and tap F8 repeatedly as soon as the light comes on. Choose 'Last known good configuration' using your keyboard. Then press enter. Try if you can login now.
Dec 15, 2008 | Dell F3534 Touchpad
Locked computer
Bugsy, just in case-have you tried without a password? By pressing and holding down the power button 5+ secs will power down the machine. Removing the battery will shut it down too. The issue is "will you still be locked out when you reboot?" You should try starting in safemode when you reboot (pressing F8) during the initial boot process and see if you can log in as administrator(no password). If you can access safemode try to reset the administrators password in user accounts. Let me know if you've made any progress. Tim
Feb 02, 2007 | Gateway MX3228 Notebook
InFocus LP70+ Multimedia Projector Logo
32 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
