Question about Bush DVD142RC 14 in. TV/DVD Combo
BUSH BTV19SIL NOT LOADING TAPES
THIS BUSH TV /VIDEO COMBO WAS BROUGHT IN TO ME LAST WEEK, WITH TAPE JAMMED IN.
I REMOVED THE TAPE BY DISCONNECTING THE MOTOR, AND JUST POWERING THE MOTOR.
NOW RECONNECTED, THE MOTOR WILL EJECT A TAPE IF PARTLY INSERTED, AND THEN EJECT IS PRESSED, BUT IT DOES NOT LOAD OR ATTEMPT TO LOAD.
THE SMD IC ON THE VCR HEAD & LOAD /UNLOAD MOTORS IS AN LB11883N
I'M LOOKING FOR THE MOST COMMON CAUSES IN THIS SET FOR LOAD FAILING.
m
M CARTER RESTORATION OR REPAIR
    Sergeant:
  • 291 Answers
There is a small CAM under the foward\reverse takeup wheel. Like a combination lock, must be set in proper sequence to send a signal to eject or load tape. Panasonic VCR has them also.
Hope that this helps, Buddy
P.S. The motor\rubber assembly MUST be set in such a way that the "end of Rubber band line" reaches a certin point WITHOUT turning any more then neccessary because it wll through the switch off aligement.
The LED that the VHS tape covers when it comes down on top of and covers it will give the same problem when it is " caca ".
Posted on May 12, 2008
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
BUSH BTV19SIL, TV/VIDEO COMBI
hi
the connection interfacing the tv and the combo must be loose...try to open and disconnect it and reconnect it
Feb 07, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Bush tv combo TV/VIDEO BTV19sil
If there is not a button marked 'Menu' You must have its remote control to adjust anything.
Oct 24, 2013 | Bush Televison & Video
My bush btv19sil is all fuzzy and i can't find the remote. WHAT DO I DO
get connected to
bush tv remote replacement . com
you will find the remote you need.
Mar 28, 2009 | Bush 2871NTX 28" TV
Samsung camcorder
Although my question might sound stupid, but did you charge the battery? The camera should be having a li-ion battery, which does not retain its charge for long(a week or so) which gives the battery a longer life.
If this is not the problem, could you explain the "ticks like a clock" in detail.
I could also be due to the tape getting jammed.
Mar 19, 2008 | Cameras
Video Tape picture shakes horizontally
needs tape path alignment or cleaning done
Jan 15, 2008 | Philips DVDR3320 DVD Recorder/VCR
VCR kicks out cassettes
Sounds as if something got bent in the loading mechanism when you freed the stuck tape. Careful examination of the loading operation with the cover off may reveal the problem, but you may require a service shop, as there are hazardous voltages present inside, even when switched off.
Jul 13, 2007 | Toshiba MW24F52 24" TV/VCR/DVD Combo
Tape Loading Error
theres a loading problem with the mechanism. It could be a nylon cam thats cracked and thrown it out of mechanical alighnment??? this is not for the handy man repairer!!! this should be taken to a repair shop for an estimate! as there are hundreds of volts inside a tv that can cause you to be seriously killed!!
May 20, 2006 | RCA T13062 13 in. Combo
Bush DVD142RC 14 in. TV/DVD Combo Logo
135 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
