Question about HP PSC 950 All-In-One InkJet Printer
Ink cartridge How do i check the level of ink in my ink cartridge?
You can get a estimate amount only by using the HP Digital Imaging Monitor or when printing, the ink levels will show up.
Posted on Feb 07, 2008
Pixma 2200 series all in one
Don't use refill kits, they are no good in quality printers. Also the cartridges in the newer models have a chip in them that knows when the cartridge is empty. When it becomes empty, the chip has to be reset, and this is what those mall cartridge fillers do.
E, 1, 3 The ink may have run out. The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected. If you want to continue printing without this function, press the machine's Stop (Reset) button for at least 5 seconds. Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities. Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Checking the Ink Status Checking the Ink Status with the Ink Lamps on the Operation Panel The ink level detector is mounted on the machine to detect the remaining ink level. The machine considers as ink is full when a new FINE cartridge is installed, and then starts to detect a remaining ink level. If you install a used FINE cartridge, the indicated ink level of it may not be correct. In such case, refer to the ink level information only as a guide. When remaining ink cautions or errors occur, the error code will be displayed on the LED (Light Emitting Diode) to inform you of the error. Check the error code and take appropriate action. -> [ An Error Code Is Displayed on the LED ] See[Checking the Ink Status ]
Oct 27, 2015 | Canon PIXMA Office Equipment & Supplies
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
I want to check ink levels. It is blurring the color when printing
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer.Checking the ink levels on a Windows computer
  1. From the HP Director , click Settings , Print Settings , and then click Printer Toolbox .
  2. Click the Estimated Ink Levels tab. The estimated ink levels appear for the print cartridges.
Checking the ink levels on a Macintosh computer
  1. From the HP Director , click Settings , then click Maintain Printer .
  2. If the Select Printer dialog box opens, select the HP PSC, and then click Utilities .
  3. From the list, select Ink Level . The estimated ink levels appear for the print cartridges.
Jun 21, 2011 | HP LaserJet CP1518 Printer
How do I check my ink levels
Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
  1. Open the printer Toolbox. To do so, do one of the following:
    • Open HP Solution Center, click the Settings menu, then point to Print Settings , then click Printer Toolbox .
    • Right-click the HP Digital Imaging Monitor in the tray, then point to your printer model name, and click Display Printer Toolbox .
    The Toolbox opens.
  2. Click the Estimated Ink Level tab. The estimated ink level gauges display.
Method three: Check ink levels from the Setup menu
  1. Press Setup on the printer control panel.
  2. Scroll down and select Display Ink Gauge . The Ink Gauge status from the Tools menu will only display on the color graphics display.
Let me know if you have any other questions. Please rate this solution. Thanks.
Mar 15, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I am unable to print on my HP Officejet Pro 8500. i have recently replaced the 940 black cartridge and since then have been unable to print. i notice there are print cartridges in the main body as well...
you can check the ink level from following steps Method one: Check the ink levels from the idle screen on the color graphics display Look for four icons at the bottom of the color graphics display. The icons represent the ink level remaining in each of the four color ink cartridges: black, yellow, light cyan (blue), and light magenta (pink). A larger and more accurate view of the ink levels can be displayed from the Setup menu. If an ink cartridge containing non-HP ink is being used, a question mark displays instead of the ink drop in the icon for that cartridge. The HP All-in-One cannot detect the amount of ink remaining in ink cartridges that contain non-HP ink. Figure 1: Non-HP ink iconc00841629.jpg NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage attributable to the use of non-HP ink will not be covered under warranty. If a hollow ink drop icon displays, the ink cartridge represented by that color icon has very little ink remaining and will need to be changed soon. You might be able to continue printing for a short period of time with ink remaining in the print head assembly. Replace the ink cartridge when the Replace Soon warning message displays on the color graphics display. Figure 2: Low ink level iconc00841630.jpg When the Empty Ink message appears on the color graphics display, the indicated ink cartridge is out of ink. Replace the indicated ink cartridge. Method two: Check ink levels from the Windows computer The estimated amount of ink remaining in the ink cartridges can be checked from the computer. See the on-screen HP Director Help for information on checking the ink levels from the Printer
    The Toolbox opens.
If the ink level is low and the cartridge is new please contact the dealer from whom you got the cartridge and if it shows that the ink level is good enough please comment so that i can give you another step to perform
Dec 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I have a hp psc 1310 series printer and i can not find the site to check the ink levels. The book says to use the hp director on page 28.
Checking the ink levels A message will appear on the front panel display when the ink level for the print cartridge is low. The ink levels can also be checked through the HP Director on the computer. Checking the ink levels on a Windows computer
Oct 05, 2010 | Office Equipment & Supplies
How to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Jun 02, 2010 | HP Officejet 6500 Wireless All-in-One...
How do you check the ink levels of the cartridges on a hp deskjet 940c
If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing when the printer’s top cover is opened. When you open the panel the ink cartridges slide to the center , as far as checking the ink level find and right click on the printer icon, click properties, and find ink cartridges and ink levels.
Thanks
Shereena.
Apr 22, 2010 | HP DeskJet 940c InkJet Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
HP PSC 950 All-In-One InkJet Printer Logo
118 people viewed this question
Seeker5211
Seeker5211
