Question about Garmin Nuvi 660 GPS Receiver
Can't get satellite fix
I have tried several times to get a satellite fix with my new Ifinder hunt but the unit will not lock on any satellites, i have checked to make sure that the unit is not in simulator mode or in the use indoors mode but still can't get a fix, this unit is brand new and never used before. is there any sugestions?
Question: My Nuvi 3xx will not acquire satellites
Answer: Please follow though the instructions below, this should rectify the problem you are currently experiencing.
Please try the following:
  • Turn your unit off.
  • Press and hold your finger on the top right hand corner of the screen along with the power button.
  • When unit powers up then release power button. Then wait for message about erasing user data to appear. Release finger when you see this message and then answer "yes" to it.
  • The unit will continue to the start up screen.
  • Put outside in a stationary position for about 45 minutes so it can pick up satellites.
Please note: the master reset will erase any recent favourites.
After you have completed the above you will need to update the latest software.
Please see the following instructions:
Connect your unit to your computer- go to www.garmin.com Go support-then go to updates and downloads-then go to additional software, choose your unit-then download and run.
If you are still facing problems please do not hesitate to contact us through your myGarmin account.
Posted on Feb 24, 2008
  • 80 Answers
Keep in mind that GPS uses "Line Of Sight" for success.... in other words, the unit satellite antenna needs to pick up 3-6 GPS sats in ourder to determine one's lat/long position. Make sure the antenna is clearly visable to the sky.
If this is not the issue... Warranty replacement may be the only option where you bought it.
Posted on Feb 07, 2008
I have a ifinder hunt GPS, it will not locate any satellites, it then prompts me to stop searching or continue to search for satellites. I have been trying this device over the last 10 months, mostly on...
With a normal GPS device, when you first switch it on, it needs some time to locate enough satelites. Most of the time it needs at least 5 satelites. Some time should be like minutes and not hours. After the GPS device fond enough satelites, it knows where it is and can when it is switched on again work faster. When you try to let the GPS search for satelites indoors, or without a free view to the sky, it is possible the receiver never can find satelites at all.
I don't know if any test of the Lowrance iFINDER Hunt GPS was placed on the net, but that is where you can check how long it should take for the GPS to find enough satelites.
Oct 30, 2013 | Lowrance iFINDER Hunt GPS Receiver
I have a Garmin Nuvi 300 model and from last few days its not picking the satellite signals when I open the antenna, it keeps saying searching for satellitie signal. What could be problem & can it be...
Hello there,
As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes. If your unit has not been used for an extended period of time (more than a month), it may take 3-5 minutes to acquire satellites. If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal. If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased. If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions. If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites. If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*. If your unit is still having trouble acquiring satellites, please ensure that it has the latest version of operating software by using our WebUpdater program. Once your unit is updated please allow the unit to acquire satellites outdoors in a stationary position with a clear view of the sky.
*Note: Some units may not be compatible with an external antenna. Please check the Compatible Devices tab on the external antenna's page to see if your unit is listed.
Hope this was helpful to you. Goodluck Elect_Comp
Sep 01, 2011 | Garmin GPS
I have a garmin 260 and lately when I turn it on it takes a very long time to acquire satelites.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As GPS units are used, data is gathered which helps them acquire satellites quickly at the start of each use. If a device is used daily it should be able to acquire satellites in a minute or less. Using a GPS device while it is outdoors with a clear view of the entire sky is the ideal condition for acquiring satellites. Please know that there can be several different factors that may cause a GPS unit to not acquire satellites:
  • If your unit is trying to acquire satellites for the first time, it may take longer than normal to establish an initial position. If the unit is powered on and outdoors with a clear view of the sky this should not take more than 3-5 minutes.
  • If your unit has not been used for an extended period of time (more then a month), it may take 3-5 minutes to acquire satellites.
  • If your unit is indoors, it may not acquire satellites. Even standing next to a window indoors will block a majority of the sky which is needed for a device to locate and lock onto a satellite signal.
  • If you have just finished updating the software in your unit or you have performed a master reset, your unit may take 3-5 minutes to acquire while outdoors as the data that is used to locate satellites may have been erased.
  • If your unit has traveled over 500 miles while turned off or not tracking your travel, it may take 3-5 minutes to acquire even in ideal conditions.
  • If your vehicle has a protective coating on its windshield or electronic devices which interfere with the unit receiving signal, your unit may need an external antenna* in order to acquire satellites.
    • If you suspect this to be an issue, try taking the unit outside of the vehicle with a clear view of the sky for 3-5 minutes so that the unit can acquire satellites. If your unit loses satellites once moved back into your vehicle you will most likely need an external antenna*.
*Note: Some units may not be compatible with an external antenna. Please check the Products tab on the external antenna's page to see if your unit is listed.
Jan 16, 2010 | Garmin nuvi 260W GPS Receiver
While driving Garmin Nuvi 250 constantly loses satellite signal. The screen says that it is aquiring a signal. It is also constantly refiguring the route.
Nov 12, 2009 | Garmin nuvi 250 GPS Receiver
Nuvi350 doesn't locate any satillites. What can I do?
Jul 11, 2009 | Garmin nuvi 260W GPS Receiver
Garmin 260w won't acquire satellites
Jan 30, 2009 | Garmin nuvi 260W GPS Receiver
Screen appears to freeze up
Try updating the unit software. A new satellite was launched this year and has been causing problems. The updates from Garmin fix it. Disable the WAAS in the meantime and see if that solves the problem in the meantime.
Dec 06, 2008 | Garmin eTrex Legend GPS Receiver
New Garmin 330 stuck on kansas
Take the unit outside and turn it on. Then select View Maps, at the top of the screen it will say either "Locating satellites" or "Acquiring Satellites". Once the garmin has locked onto the overhead satellites, then it will say "Ready to Navigate".
Locating Satellites take longer than Acquiring Satellites.
Jun 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
184 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
