Question about Compaq Presario 1800 Notebook
Some keys not working but windows loading properly
In my Laptop, Windows loading properly after that most of the keys are not working.
In CMOS setup also keyboard not working
    Problem Solver:
  • 5 Answers
Your laptop have hardware problem so please contact service persion.
Posted on Feb 07, 2008
Fn key
You could map that FN key to another unused key in Windows such as use the "[" or "]" key mapped as FN. Requires DOTNET Framework 2.0 to operate.
http://download.cnet.com/microsoft-net-framework/3000-18513_4-47206.html
http://mapkeyboard.inchwest.qarchive.org/
if no joy try it in safe mode
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
restart your computer press and hold the delete or f2 key to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
or
hope this helps
Jul 15, 2012 | Panasonic Toughbook W4 Notebook -...
ASUS Windows 7 laptop cannot keep time! I have checked the bios, and the CMOS battery, and all seems fine. Yesterday it lost 13 MONTHS!! What is wrong?
hi charli, did you change new cmos batter , how you checked your bios cmos battery, if you not changed your cmos battery try to change and check it you may get proper time.
GOOD luck
Dec 31, 2010 | ASUS Computers & Internet
I cannot get to Windows XP even tried F8 function and F2 as well as F12. All it does is load Dell and then the screen goes blank
Hello sewelika, hi, your laptop has main board problems, this are the things that should be checked, sorry there are no quick fix on this.
  • check battery/CMOS battery as well, this may cause the laptop have wrong idea of what hardware are connected.
  • check for memory which causes your laptop not to boot.
  • check for Hard drive this causes window not to load, and
  • Mainboard this causes all the above not to work properly.
Sep 11, 2010 | Dell Latitude D505 Notebook
My hp laptop 22mths old wont keep time. very time i switch it off it wakes with time it was switched off at? is it the cmos battery? no warranty.
Hi
Thank you for your query
From your description, indeed it does sound like the CMOS battery, however the vest way to check is next time you start the Laptop do the following
1)When loading the laptop there will be a message that says hit F12 or hit the del key etc etc to get into bios, press the appropriate key, if there is no such messgae try the keys F12, del or esc
once in Bios check the time if it is incorrect then it is the CMOS battery, if it isnt then it is windows related
However from what you are describing it does seem to be the CMOS battery
If this has been useful please leave positive feedback/vote/testimonial as this will help me greatly - Thank You again
Feb 12, 2010 | Acer Aspire One PC Notebook
My gateway laptop stays on the windows xp loading screen after turning it on and just carries on loading friends of mine say it could be the hard drive
NO ITS NOT THE HARD DRIVE ITS JUST A MINOR PROBLEM WITH OPERATING SYSTEM INSTALLED IN UR LAPTOP
PLZ REINSTALL UR OS 1CE AGAIN IT WILL B FASTER
Aug 25, 2009 | Computers & Internet
Time/date never stay set.f1 f2 f3 always there on start up
This sounds like the cmos battery is low.
This battery sits on your motherboard and provides the ROM with energy. Replace this small battery, set date and time a final time and then it won´t happen again.
May 28, 2009 | Computers & Internet
Error code 0f00::065d msg:IDE failed self test failed read portion . Msg: Ide device failed blank media or no media present in optical drive error code ofoo:137B This is a Dell laptop inspiron 1300
its simple:
1. Get Windows XP Booteble CD from a friend or simple download it
for example "WINDOWS XP PRO sp3 x86 32 BIT"
2. Burn it on CD
3. Switch on your Laptop/PC
4. Press F12
5. Put your Windows XP to your CD/DVD drive
6. Choose from a manu DVD/CD
7. Press any key to start instalation
8. wait a couple minutes and pres R for Repair
9. wait until you will se C:\
10. and finally type "chkdsk c:"
11. after all restart laptop/pc
12. Enjoy
Sep 06, 2008 | Computers & Internet
Laptop ntldr problem
When pc first starts, press the F2 key to open the pc cmos settings. Look around and find the boot list and ensure that the machine will boot on cd before hdd. Than boot on your OS cd and attempt to repair existing. This will at worse case reinstall your system.
Dec 05, 2007 | Microsoft Windows 98 for PC
How to reset power-on password.
The only way is to clear the cmos settings. However, there is a special way to do it. First you have to take out the battery and the power adaptor from the laptop. Then you need to open the laptop and look on the main board for the cmos battery. Take it out for a few minutes, maybe 5 - 10 minutes. Then plug in the power adaptor without the cmos battery nor the laptop battery and boot the computer. It will ask you to hit F1 to either load default values or to save settings. Do that. Then shut down the computer. Make sure settings is saved though. Put in back the cmos battery and the laptop battery. When you reboot, it should boot up with no password.
May 02, 2007 | HP Compaq Business NX9110 Notebook
Compaq Presario 1800 Notebook Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
