Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
ANY DRIVE DOESN'T OPEN????????
PLEASE TELL ME "MY ANY DRIVE DOESN'T OPEN WHAT SHOULD I DO????????
  • 4 more comments
  • dksk14785 Feb 10, 2008
    my any drive doesn't open when i double click on it
  • esvark Feb 10, 2008
    when i open my c drive it shows a window like open with options:
  • Anonymous Feb 14, 2008
    I Have formatted my PC because of having some virus in my PC. After loading the XP sevice pack 2 & Symantec Anti virus I am not able to open the other drives except C DRIVE
    same problem
  • kigi Feb 24, 2008
    any of my drives doesn't open.it says :application cannot be run in win32 mode. i have formatted one drive and only that drive open
  • satash May 11, 2010
  • 118 Answers
It's a virus, undetectable with antiviruses, there is a file named autorun.inf in the drive delete the file and recheck it.
Posted on Feb 07, 2008
  • Mohammed  Rahman
    Mohammed Rahman Feb 07, 2008
    Try out a latest antivirus. Avast is great. And use right click open to open drive as not to activate the virus again. And next time dont forget to check any removable drives especially Pendrives before opening it. Take Care
Well friends, This is satya here , I am going to give you Quick tips, Just follow it:
First go to run then write " regedit" that is registry
then find " ctrl+f"
in this box write "mountpoints2" and delete it ......
then again press "ctrl+f" again find mountpoints2 until all these files are not deleted
then u will see ur problems is solved.
It will definitely help you out .
For more visit : http://ibibo.com/satyaiitk
Regards
satyaiitk
Posted on Sep 23, 2008
Nikki u should run ur drive from start menu.
  • CHANDRAMOHAN  SINGH
    CHANDRAMOHAN SINGH Feb 14, 2008
    nikki u should run ur WINDOWS XP SERVICE PACK 2 named cd & then repair it.
    GOOD LUCK.
    RATE THIS TOO
  • 41 Answers
IF the problem comes after formatting it,..........use quick heal antivirus,...........it is the best antivirus for .exe file virus,.(Autorun)..............or use naevius_usb_antivirus,.........for it,.................it will finish your problem permanently,..........if u don't have that ,...........search it on cnet.com,,,,,,,,,,,,,,,
Posted on Dec 05, 2009
Drive does not open, openwith window / dialog comes -
remove all viruses, Trojans, or similar notorious things, remove autorun.inf, openwith internet explorer - http://benteak.com
Posted on Aug 25, 2008
If somone is still looking for the solution here it is:
- First check for viruses, then delete them. Be sure to also delete the autorun.ini file along with the virus. Most likely the virus has copied itself on each drive, so repeat the process for each drive. (Be sure to check the "show hidden files" option from the folder options, so that you maybe able to delete the autorun file which may not be detected by your anti virus program.)
I was having the same problem. There was this virus xp19.com. I deleted it but forgot to delete the autorun.ini file. After deleting the autorun file, the problem completely finished.
- Another (rather annoying) solution is that when the open with window appears, open the drive with internet explorer, it will work same as windows explorer.
- Another (rather time consuming) solution is that first backup all data on the drive, (only the visible files, not the hidden ones, except if its a system drive, ) then, format the drive. Now put the data baack on the drive. Your problem will be most likely gone.
- How to format a drive: (Note that all files will be deleted after format, thats why be sure to backup the data.) Right click on the drive, select the format option. There are no settings to change. Just format the drive using FAT 32 file system. Dont format your C drive. Instead, you can easy reinstall Windows in short time.
Posted on Jul 20, 2008
When i open my c drive it shows a window like open with options
Posted on May 26, 2008
Install Avast Antivirus n reboot the system then move infeted files to chest r delete by using the options provided their
Posted on Mar 11, 2008
What's your problem? cd drive won't open
if you have warranty - contact the repair center, if not, open the case and check if the power plug of the Cd/DVD drive is all the way in. unplug it an then plug it back in again.
If that doesn't help - buy a new drive. they are like 30$ nowdays and install it the same way in like the one that doesn't work was installed.
Mar 12, 2012 | Gateway FX685051u Gaming Desktop
My xbox won't read my dvds it tell me to open tray
you should try cleaning it with an actual dvd cleaning disc. if that doesn't work you may need to get a replacement drive and swap them out.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Mar 03, 2012 | Microsoft Xbox 360 Console
I put data in my sd card & played some songs in my lg gs290. But when i formatted the memory card from my cell phone it didn't remove names of tracks from my lg gs290 default music player. I reset...
Put the SD Card in your computer. Open my computer, right click the drive that corresponds to the card, and click "Format...". Do a complete format. That should fix it!
Please leave me a good rating, thanks! :)
Jul 27, 2011 | Computers & Internet
I can't open my FLASH DRIVE it says that "please insert a disk into Floppy Disk Drive (E:), How can I open this? please help me.. I have only 1 flash drive and I don't have an extra money to...
First thing to do is to safely remove your flash drive..
then insert it again...
If it doesn't work then your final choice is to make loss of your data..
here's how.
on the icon shown from your flash drive right click
then format..
You can select quick format in there..
and there you go again,, you can use your flash drive now....
Jun 27, 2011 | Computers & Internet
When connect my pen drive ( kingstone 8GB G2) it can connect.....it showed on my task bar........and when i open drive of it in my computer it say "please insert a disk into drive H: "...
the computer may have recognized the device as a card reader instead of a thumb drive, try inserting it into a different usb port. And if that doesn't work ,back up the files on the drive and try reformatting the drive.
Jun 17, 2011 | Computers & Internet
Dell latitude cpi d300 xt keeps saying that the Primary hard disk drive 0 not found and it says that there is no bootable devices selected and when i hit the F1 key or the F2 key nothing happens please...
What has probably happened is, your hard drive is probably dead Basically its saying it doesn't see the drive so it can't boot. It could be either the drive or the motherboard.
May 17, 2011 | Computers & Internet
Please help me! Mine CD/DVD Rom is reading after a long time ! Some time it doesn`t read or write.... Please help
oh...maybe your drive need to be cleaned....if u knw how to open your drive...just open it then use a soft cloth or cotton to clean the lens....be careful...the lens is sensitive...
Dec 09, 2010 | Microsoft Windows XP Professional SP2
Please tell how to open the case.
Richard,
How do you know the drive is no good?
Lets get real now ...
Dont be so hasty to tear this up. What is the point anyway ... the drive is worth about $100.00 - the case about 80 cents. What are you saving by opening the case?
Did you buy this in the last 30 or so days? If BB will not talk to you ... did you use a credit card to purchase, call the CC company and tell them what happened.
I think the CC company will help you.
Thanks for using FixYa.com
Positive comments welcome
a
Oct 28, 2009 | Computers & Internet
I dropped my hard drive and it doesn`t work now. it makes a louder noise than usual too please help?
open the drive to make sure that nothing is detached from its oroginal location or position.
Oct 09, 2009 | Buffalo Technology 1TB DriveStation...
Pen drive not open
Try this - Start -> Run -> G: or H: (what ever drive it picks up).
If it opens then there is virus called autorun.ini in your pen drive.
Sep 26, 2008 | Pen Drive IVO MP3 Player
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
448 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
