Question about Dell /nVidia Ti4200 GeForce4 64MB w/TV Out AGP Graphic Graphic Card
I have a problem in sound no sound in system. system is dell p4 No sound from vidio's Cd's even though volume is set high. sound listed as ESS Maestro audio Drive WDM. Status OK
  • 118 Answers
Please reinstall your sound card drivers
you can find more info from here
http://www.esstech.com/techsupp/drivers.shtm
Posted on Feb 07, 2008
    President:
  • 4,402 Answers
Open the case up and make sure the cdrom has the audio cable connected you should have a power cable a data ribbon and audio cable
Why won;t my volume shadow copy stay on or work?
VOLUME SHADOW COPY and sound functions have nothing in common other than both exist on a computer.
for volume icon, rt clk system tray expand button and select properties. Then turn volume on.
Sep 01, 2014 | Dell Latitude D610 P4 1.6 GHz CDRW/DVD...
No audio even i already installed the audio driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 02, 2011 | Asrock P4VT8+ P4 PT800 Prescott Ready...
I have dell studio1555 laptop and i turn on the all the volumes and set them to high but still speakers are not working.
hi...volume wide open but no sound,, check your setting configuration on your setting control panel and look for sound & audio device, also check... control panel system see if you dont have any yellow mark indicate missing drivers, if yes... re-install your sound drivers from your CD-recovery if you have one, if you dont have one, you may have to look on exemple.... dell.com and look for drivers & update
Oct 25, 2010 | Computers & Internet
Unable find required drivers ess.maestro
Here goes a list of the existing drivers for ESS.
Unfortunatelly I can't help you much more unless you tell me the chip code.
http://drivers.softpedia.com/get/SOUND-CARD/ESS-AUDIO/
Hope it helps
Jun 20, 2009 | Intel ESS ES1868F Sound Card
Low volume on finalized songs.
There's not really any magic fix to this as far as I'm aware. I usually don't burn CD's from my Tascam directly, but export the mix to the PC and do final touches and burn from there. I don't typically normalize though and the levels are what has come out of the Tascam. I do however use compression on many of the tracks (and sometimes on the whole mix) before exporting which will squash the peaks and lows together and thus give you an overall higher volume with your level meters peaking in the normal place you're used to.
There are other factors like EQ without which a mix can sound too loud and perhaps cause you to lower the levels when really things in the mix just need to be allowed to sit in different EQ bands.
Compression is the key though. Unfortunately even well recorded instruments and vocals naturally contain wide fluxuation in terms of lows and highs and these need to be smoothed out in order to obtain anywhere near the volume of a commercial CD. With compression alone the result may still fall short as the use of pro quality mastering effects can really make a world of difference to overall percieved volume as well.
Hope this helped
bd.
Jan 26, 2009 | Tascam DP01 All-In-One Recording Package...
My dell wouldnt post,
It sounds like the motherboard is damaged. Did you try to start with a boot cd? Or will it just not get to the bios setup screen?
Nov 28, 2008 | Dell Dimension 3000® Pentium® 4...
No sound for my dell inspiron 5000 notebook
Download everesthome
Install and run the program.
click on motherboard tab on left
click on chipset
click on southbridge in right column
the southbridge is the id of the audio chip set
the audio controller will be listed
google the chipset driver or audio controller driver.
Mar 30, 2008 | Dell Inspiron 5000 Notebook
Check device manager. Uninstall sound card .Scan for hardware changes or run cd.
Let me know how you make out.
thanks
Dec 06, 2007 | Dell /nVidia Ti4200 GeForce4 64MB w/TV Out...
Volume setting is very high
That is unusual, and sounds like a manuf defect. If your unit is still under warranty, I would say send it in. If not, give them a call, and get a quote for repair. Unfortunately, due to the quality and value of these units, it will probably be cheaper to buy a new one.
Sep 21, 2007 | Crosley Conductor CR73 Turntable
Dell /nVidia Ti4200 GeForce4 64MB w/TV Out AGP Graphic Graphic Card Logo
234 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
