Question about RCA OPAL M4001 MP3 Player
Help? I got an opal and it worked for a bit,now that I put new songs on it, when I try to play them the mp3 player just shuts off and it has to load the database when I turn it on again. None of the songs work and I think it's because I didn't safely disconnect the hardware but there is no option for that. What do I do?
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Posted on Feb 09, 2008
My m4204-a rca opal mp3 player won't come on. one day i added some songs to my mp3 player and it was working perfectly. later when i turned it on it shut down immediately. the battery was full and i tried...
http://www.nikeexpert.com/
May 31, 2010 | RCA opal MP3 Player
M4002 RCA Opal says it is now playing, but doesn't move forward
Many updates end up deleting all songs off your player as a side effect - try reloading your songs onto the Opal and see if they will play after that.
Also, make sure the hold/lock switch wasn't accidentally activated.
Another possibility is that one of the updates made a change to which DRM licenses the player is compatible with. If you have songs with an older DRM-9 license, they may not be usable after the update. which music service do you get your songs from? If it is a licensing issue, then I would try loading only songs that are in mp3 format - they will never give you funky issues.
-Tha Mp3 Doctor
Mar 15, 2009 | RCA OPAL M4001 MP3 Player
My rca opal 4gb will not add more than 39 songs
hi teddy,
first try to format your player, if it has an option to do that. secondly ensure that the bit rates of the music files are in following ranges: mp3: 32-320kbps & WMA: 48-192kbps. and if u have uploaded pictures (.jpg) files into it then ensure hat they are not very high in number bcoz it can support upto 2000 items only including music and video and picture files.
try these.. hope they will help..
Dec 28, 2008 | RCA M4204 MP3 Player
RCA Opal MP3 player stuck on "keys locked"
Push down the key lock switch, I think on your model it is on the side of the unit.
If it does not work, try performing the reset procedure below, From
ThaMp3Doctor
I quote
"Opal has a reset hole on the back of the unit in which atoothpick (non metallic) can be inserted to reboot the player. If thisdoes not work, I suggest that you reformat the player by using theWindows format command on the unit. To reformat the memory:
Right click on the device within the Explorer or My Computer window
Select the format command (full format) to reformat the internal memory of the device. "
If it still does not work, then the lock switch is probably faulty or stuck inside, in this case you need to take apart the unit, to fix it.
Try playing with the lock switch, or resetting the unit, that should unlocck your MP3.
Oct 07, 2008 | RCA OPAL M4001 MP3 Player
My mp3 player is messd up!
silicone headphones it come with are screwed up! becaude I changed the headphones and the some sound clear again!
Apr 13, 2008 | RCA OPAL M4001 MP3 Player
The DRM license on those songs was fixed term - renew the subscription to your music svc to get them to work again.
Mar 19, 2008 | RCA OPAL M4001 MP3 Player
Rca
Reformat the player
Mar 18, 2008 | RCA OPAL M4001 MP3 Player
Will not download songs
i had the same problem. and the answer made me so mad. turns out, you have to have yahoo unlimited TO GO in order to transfer the songs. i found this out after not only suscribing to y! unlimited but also downloading 400 songs! ugh. i still haven't found any service that works with it, and i've been searching all day.
Dec 25, 2007 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
22 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
