Question about Whirlpool MH1140XMS Microwave Oven
MH1140XMS Oven Stays On
First of all My father and I broke the light bulb under the microwave away from its screw in base during thanksgiving. I left the light bulb because im lazy. Not sure if this is what caused the problem. 2 months later I am cooking and i see an arc. Not sure what it was i unlugged the microwave and let it sit. I plugged the Microwave back in and it turned on and would stay on if I opened the door. I could smell burnt electronics so instead of replacing it at 300 dollars I decided to order a new controlboard from http://www.appliancepartspros.com ($115) it was here in 2 days. Replaced the controller board last night. Seems a diode had fried ( i could see the burn marks on the underside of the controller card). Installed the new board last night an its working like a champ.
  • 2 more comments
  • ryancoc22 Feb 11, 2008
    I already fixed it. i just wanted to let everyone know what the symptoms were and how i fixed it.
  • ryancoc22 Feb 12, 2008
    It smoked a diode on the board. can you fix that?
  • William Miller
    William Miller May 11, 2010
    Let me be sure that URL is right:http://www.tinyurl.com/yzjozk
  • William Miller
    Let me know if you would like the old board repaired. We do that for $39.95 for customers nationwide.
    Our link is on our FixYa profile here:http://tinyurl.com/yzjozk
  • Whirlpool Master
  • 9,098 Answers
Right, but I wondered if you might want the OLD broken board fixed, too, as a backup? Keep it in mind, It's only $39.95.
Posted on Feb 11, 2008
  • William Miller
    William Miller Feb 13, 2008
    Sure, we'll replace that, too. It's probably the brightness diode.
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
No socket for bulb on left side of oven
The oven cavity lamp is hidden up on top. You have to unplug the oven and remove the single piece top/side cover to get at it. Typically, you have to take out screws on the back of the oven along the top and side edges. Sometimes there are also screws in the sides and rarely along the bottom edge. Once you get these screws out, pull the cover back about 1/2" and lift it away. Look for a standard appliance light bulb right over the holes in the oven cavity ceiling or wall where the light normally shines in.
Dec 30, 2010 | Maytag MMV4203D 1100 Watts Microwave Oven
LG Microwave oven Tried to remove the countertop light bulb. Glass came off metal base still in unit. How do I remove the base, ist screw type bulb?
try using a small potato,push it into the base while turning the potato.it may lock onto the base and unscrew it....UNPLUG IT FIRST...
Nov 16, 2010 | LG LMV1630ST Microwave Oven
Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I cannot tell how the 2 bulbs (surface light(s)) detach. One of them broke when I was trying to remove after it had burned out, and the glass part of the other bulb turns freely and is very loose and...
Unplug the microwave oven and get a needlenose plier and a flashlight. Wear some hand protection since you are working with broken glass.
Most of the bulbs I have seen are screw thread mounts.
For the bulb with the broken glass, use the needlenose plier and try to find the screw thread for the bulb. It should be screwed in to the lamp socket of the microwave. Carefully grab a hold of the outer edge of the bulbs screw thread and turn it counterclockwise to loosen it from the base. You may only be able to turn it a quarter turn before letting go of the bulb's thread and getting a grip on a new position to continue turning. Inch your way to remove the broken bulb's thread.
If the other bulb still lights up, I'd leave it alone.
Aug 09, 2010 | Hotpoint RVM1325BW Microwave Oven
I have a light bulb that broke and I cant get it out, does it push in or screw in?
Chances are it is a boyonet base bulb. Unplug or turn off the power to the microwave. To remove the bulb, press in lightly, turn the base of the bulb counter-clockwise about 20 degrees till it stops, then it should pull straight out.
May 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Whirlpool MH1140XMS Microwave Oven Logo
87 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
