Refrigerators Logo
Posted on Feb 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Freezer burn on ice-cubes
I have a Maytag fridge that has black mold around the freezer section gasket. Also the ice-cubes have a terrible freezer burn taste after only a day. Are they related problems and how can I fix my poor tasting ice-cubes?
  • Anonymous Mar 14, 2014
    the ice in my freezer tast like dust
kcoatney
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 12, 2008
kcoatney
Contributor
Level 1:
Answers
Questions
0
Helped
2592
Points
Well, this is just a weird question I wanted to ask.
My fridge isn't fancy, so we've got the ol' ice cube tray's, fill them up, and the like.
Okay, I've noticed that fountain drinks have ice that is pretty clear looking.
Ours in the freezer are kind of frosty white and I think my dr. pepper taste horrible when I use the ice cubes here.
Why in the world do my ice cubes taste weird all of the time?
Ha!
Kylee*
Anonymous
Level 2:
Novelist:
  • Expert 87 Answers
  • Posted on Feb 08, 2008
Anonymous
Expert
Level 2:
Novelist:
Answers
87
Questions
Helped
49280
Points
136
Black mould around the freezer seal is normal if it has built up over a long period of time or has stood in damp environments. Normally hot soapy water can clear this right up. The ice taste would probably be resolved by fitting or changing the water filter, and / or cleaning the ice maker module located at the top of the freezer section and any route that the ice would take. Cleaning solutions for ice makers are available you just might need to call a local engineer for some advice on where to get some in your area. Hope this helps.
Anonymous
Level 1:
  • Posted on May 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2592
Points
Try a spray bottle of vinegar and an old toothbrush for the seals---hoses leading to the icemaker might need to be replaced
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
1helpful
Why is water coming out under the refrigerator?
Maybe the freezer defrost drain is blocked. Sometimes the water freezes in the drain and the next time the defrost cycle occurs the water can't drain correctly. Is there any water inside the refrigerated section of the unit? Also there may be a catch pan under the fridge that is misaligned or out of place or the drain line isn't positioned to place the defrost water into the pan. Most modern refrigerators are frost free and defrost the freezer on a regular timed cycle. This is why your ice cubes shrink and stick together and why you get freezer burn on the food left in them for extended time.
There seem to be so many different types of ice cube trays: silicone, plastic, metal etc. What is the best type to buy?
It sometimes is just a matter of taste. The silicone ice cube molds are more flexible and often take up less freezer space but some people don't enjoy the struggle of getting them out of the molds.
Read this article that reviews ice cube trays and gives an opionion on the best ones. For me - I still love the old fashioned plastic trays that don't flop around when you are trying to put them in the freezer;
http://gizmodo.com/5913538/the-best-ice-cube-tray-of-all-time
Jan 10, 2013 • Home
1helpful
Ice maker won't make ice after changing water filter
Have you tried adding a bit of water to the ice mold? Is their an ice cube stuck in the ice mold? If you have an ice cube stuck in there just heat the im with a hair dryer till the cube clears and fingers go around. Listen to see if you hear water going into the mold.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6helpful
The Ice maker has stopped working.
There are usually 2 small solenoid valves that are used to control water. Both are generally installed at the rear close to the bottom of the fridge. One of the solenoids controls the water flow for drinks and the other is to control water flow to the ice maker. You can determine which is which by tracing the water supply tubes from the freezer compartment to the solenoid or by process of elimination. The latter method requires that you feel for movement (clicking) or heat on the water dispenser solenoid while someone starts to fill a glass with water from the fridge.
Before going any further, make sure that the ice cube detection arm in the freezer is not up. Gently push the arm down if it is. When ice cubes are ready, the ice maker turns on a small heater to break the bond of the ice cubes to the cube mold. The arm is lifted up and out of the way. Then the mechanical fingers wipe or push on the cubes to dislodge them from the ice cube mold and they fall into the container. The arm is then lowered again and rests on top of the ice collected in the container. The position of the arm when resting on the ice cubes determines whether or not any more ice cubes are made.
If the arm is hanging down, then ice cube production should be on. The problem may be either a faulty solenoid valve (mentioned above), switch in the ice maker assembly - the detection arm in particular or wiring between.
GE side x side When ice maker switch is on, freezer warms up
It sounds like the ice maker is stuck in the harvest ( dump ) mode , in the area of mold heater activation . This area , heats up the ice mold to unfreeze the cubes , and keeps rotating to dump the cubes . This heater , gets hot enough to actually burn you if you touch the mold .
I would remove the 2 screws holding the ice maker , unplug from the ice maker receptical , and replace the ice maker .
Black spots on ice
The ice maker mold is deteriorating. Replace the ice maker.
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
My Fridge was turned off for the winter while I was away. Unfortunately my plumber left filled ice cube trays in the freezer and shut the door. Water was also left in the fridge. When I returned this...
well for mold problems i recommend cleaning out all compartments with water/bleach solution also a little bathroom cleaner will kill the mildew. i don't think it seeped to the insulation because the plastic liner in fridges are quite little thick. turn it on for some days and put one of those arm and hammer baking soda for fridges that will kill any residual odor. i consider it safe but its your call if you feel comfortable using it.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
