Question about Eddie Bauer 3-in-1 Leather 22-770
Car seat I need to know if i can use the latch system with the seat belt
  • 48 Answers
No it not recommended to use them together it is not safe use one or the other. preferable the seat belt, as latch belts have been known to com loose way way easier over time then seat belts properly installed.
Posted on Aug 07, 2008
  • 50 Answers
Hi you need to read the instructions that came with the seat and make sure it is fitted correctly or take it to the supplyer they will know DONT guess if anything happens you wont forgive yourself
Posted on Feb 08, 2008
The LATCH System for the Evenflo Symphony 65 car seat is too short for 08 Yukon.
1. Make certain you are using the correct belt path.
2. Follow the instruction manual and use the seat belt for install.
If you need help (most parents do) contact a local Child Passenger Safety Technician (or equivalent if you are not in the USA) for help. www.nhtsa.gov
Correct installation is critical to the safety of your child. Don't guess!
Mar 06, 2013 | Baby Gear
Air bag warning light came on. I brought it to the BMW dealership and said the seat belt needed to be replaced on the front passengers side. $400 plus. Thoughts? 1999 BMW 328i Sport
It is possible. The system will give codes and point them into the right direction. If it is seatbelts ( I know it seems strange) it is because they may have a charge to them, meaning that they use a sensor (to let the system know when it is latched) and when there is an accident the system deploys airbags as well as releasing a charge to retract the belts and keep you well against the seats to prevent further injury by coliding with the airbag. Replace the latch and have them reset the system. Make they know that they are telling you that this "fixes" the system not they are going to replace parts until the light goes out! Let me know.
Oct 25, 2010 | 1999 BMW 328 Series
I have a 2003 2 door sunfire. I am installing a infant car seat base using the latch system instead of the seat belt. Can I do this in the middle of the back seat or does it have to go at one of the...
Ideally if there is a middle set of latches in the seat, you can install an infant car seat base there. If the seat has any kind of hump or other irregularity then it should not be installed there. Although the middle of the back seat is safest for a child, most vehicle do not have a latch system there. However most cars do have a lap belt for the center seat and that should be used if you decide to place your car seat.
Do not use the latches from either side of the right back and left seat. The latch system is designed to be a specific distance apart to work correctly. If you don' want to use the lap belt then you should put the child seat on either the left or right back seat using the latch system.
Aug 18, 2010 | 2003 Pontiac Sunfire
How to install car seat with seat belt, instead of latch belt. illustration shows seat belt going throw where latch belt is in the base.How does the latch belt come off and the seat belt go in.
this is easy to install but need to be explain with pictures. go to google.com or youtube.com and type in search box how to install car seat with seat belt. you will get pictures showing you how it's done . good luck
Jun 05, 2009 | Graco Quattro Tour Deluxe Travel System -...
How to install infant car seat
The two clips are both for the LATCH system - they're not top tethers (which go to the back of the seat for forward facing seats only).
You need to choose EITHER the LATCH installation OR the seatbelt installation - doing both together can put too much stress on the belt path of the seat, causing the plastic to weaken.
If your car has the LATCH system, there will be two metal U-shaped anchors in the seat, where the seat back and the bottom of the seat meet. Some cars only have them for the side seats, not the middle, so check your car's owner's manual - if you don't have them specifically for the center seat, you'll have to either install with the seatbelt or put it in a side seat to use the LATCH - don't try using one anchor from each side, as they won't be the proper distance apart.
If you'd prefer to use the seatbelt to install, kneel with all of your weight in the seat to tighten the seatbelt. It's tight enough when it can't move more than 1 inch from side to side if you grab it at the belt path and pull it back and forth. You probably will still be able to pull the TOP of the infant seat back towards the back of the seat of the car - that's not a problem - it helps the seat to cradle the baby through an accident.
You need to have an owner's manual, though - to request a copy, contact their customer service at consumer@djgusa.com or call them at 1-800-544-1108.
Jan 27, 2009 | Eddie Bauer 22-625-BLD
LATCH Attached?
The latch can be used in the rear facing position.
On mine there was a screw which secured the nylon to the seat.
You need to remove the screw and remove the LATCH belt.
The LATCH belt must then be threaded through the belt location under the child's seat, rather than behind.
Pay attention if there are any arrows on your LATCH belt which point up, so that you thread the belt the right way. Remember that the seat is going to be rear facing! : )
On the side of my seat it shows a picture with the LATCH in use, threaded underneath the child's seat. Maybe your shows this too.
Hope this works for you!
Stuart
Nov 21, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Does it only work with the LATCH system?
YES JUST MAKE SURE YOU PUT THE REGULAR SEAT BELT FROM YOUR CAR PROPERLY TO HOLD DOWN YOUR CAR SEAT THE LATCH IS LIKE A SECONDARY SAFETY FOR YOUR CHILD SEAT ITS UP TO YOU...
May 21, 2007 | Britax Boulevard
The Latch Tether difficult to tighten
Could you use the LATCH belt from the last seat that you used when your child was smaller? All the LATCH belts I have seen look the same.
Nov 04, 2006 | Eddie Bauer Deluxe High Back Booster...
Eddie Bauer 3-in-1 Leather 22-770 Logo
81 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
