Question about Garmin StreetPilot c340 GPS Receiver
Display problem a garmin model c340 streetpilot only a couple of months old has started diplaying a series of lines across the screen. the unit operates fine other than the display problem.
  • 504 Answers
Have you tried resetting the unit? It sounds like you may have a problem that Garmin needs to address. I would try to reset it first, then make sure you have the latest firmware loaded on the unit. If you still have the problem, it may have to be sent to Garmin for repair.
Posted on Feb 07, 2008
Top row of number and letters not responding when I punch them in. for example #1 comes up #4, #2 comes up #5,and #3 comes up #6! How do I resolve?
To calibrate your Streetpilot c-Series touch screen, follow these steps:
    1. Begin with the unit turned OFF and unplugged from a power source.
    2. Power the unit ON, continue to hold the Power button for 1 minute.
    3. A screen will display instructing you to Press dot in the lower left corner.
    4. Release the Power button and touch the sequence of dots until your unit displays, Calibration complete.
    5. Your unit should now function normally.
I hope this helps. Please rate my reply. Thank you.
Jun 27, 2011 | Garmin StreetPilot c340 GPS Receiver
My c340 stops at "locating satellites". I reset it
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
Have a Garmin c340 and want to update maps. Have
go to the garmin site itself and answer a few questions about your unit and then follow the on screen instructions.
http://www.garmin.com/garmin/cms/site/us/maps/
Oct 09, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Jun 03, 2009 | Garmin StreetPilot c340 GPS Receiver
My garmin c340 will no longer connect to satellite
Hi
Try updating at Garmin Here
This can resolve sat problems
Regards.
Apr 15, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Screen frozen
Be aware - A Master Reset WILL ERASE ALL OF YOUR FAVORITES. To do this, turn the unit off. Press and hold the bottom right side of the screen and turn the unit on.Keep pressing the screen until the unit asks if you want to reset. Press yes. This will do the Master Reset.
Mar 30, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps
It still should be under the one year warranty with Garmin. Call Garmin support and get a RMA.
Nov 25, 2007 | Garmin StreetPilot c340 GPS Receiver
GArmin c340
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in this manual (different model but same principle, see website below) for pictures:
www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf
Please don’t forget to rate my answer.
Oct 11, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
93 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
