I think my computer has been infected by virus,the problem is the virus had been removed but when I try to open hard disk drives like c: or d: or g: it prompts me to select a program from the list,and the option USE THE SELECED PROGRAM TO OPEN THIS TYPE OF FILE is not higlighted so that I am unable to check mark it and every time I have to open it by selecting internet explorer,pls help me with this..pls give me a full description about what to do ,clearly step by step.
After removing the virus ... some of the system file has became unstable .... so you are facing this type of problem ....
so the solution is to reinstall the windows xp professional sp2 again ....
if you have very important programs which you dont have back up then just you have to do is you start the set up by boot disk of windows xp sp2 (actually all windows cd s will be the boot disk only if we just copy the exact windows cd with out changing anything especially "cdlabel")
so just insert the boot disk cd in to the drive and make the boot from cd (it must be done b4 os loads) so just have the check in bios that the first boot device is cdrom and then boot the set from cd then it will ask "press enter to install winxp" you must press enter then after it will detect the partitions for "previously installed operating system" if it detect the installed "windows xp" means they it will prompt for repair option here... you must press R here ... if you press R at the first time before detecting i mean in the previous step than this means it will take you to recovery console ....
so besure to follow these steps....
after giving repair it will repair and ur problem will be solved
How i can share my windows xp black with windows xp sp1
Http://www.safer-networking.org/en/download/index.html
download spybot and scan your system for trojans
post the results
http://www.techsupportforum.com/sectools...
download and run.
TNX
Try getting a virus scanner and remover. There is a free version by Google called the Norton Security Scan, and will let you know if you still have any viruses in your computer. If you do, you will need to get this fixed for your computer to work at its maximum!. I recommend Defender Pro where you can get it at WalMart for !9.99. Works wonders!
Kargiaa
I have some problems in my home window xp kindly update this window automatacly
my computer was infected by virus.i had installed windows xp again but d:,e:,f: drives are not opening by double click and each time prompting me to select program from list to open the file
yes,the same problem.i cannot open windows drives c,d,e....
when double click on drive c,d,e,f,g then it always display to select an option from the list to open thar drive
vfssfs
same problem as described
yes
all my microsoft word,excel gone.can help me
i can't use ipconfigÂ
My computer had been infected by virus,which i have removed but when I try to open hard disk drives like c: or d: or g: it prompts me to select a program from the list or win32 related message,and the option USE THE SELECED PROGRAM TO OPEN THIS TYPE OF FILE is not higlighted so that I am unable to check mark it and every time I have to open it by selecting internet explorer,pls give me a full description whether i can repair my window online from internet?
Solution Link . . . http://www.microsoft.com/Windows-XP-Prof...`
i want window xp frofectional 2002 servic pak to setup.. plz
