Just replaced the mains transformer as this did not appear to work. Laptop did not light up. Received new one today. Laptop now comes on but will not start up.
First page shown reads "we apologise for the inconvenience but windows did not start successfully, A recent hardware or software change might have caused this etc etc.
Page then goes to the blue Microsoft XP page and looks like something is happening with the timer thing going across the page but it then reverts back to the initial page as above. Can you help. Know nothing about PCs when problems arise!
Still not working - the screen just goes off and then back to the 1st page again. Thanks for trying to help! Any other suggestions. It was great to get a response so quick! Thank you.Still not working - the screen just goes off and then back to the 1st page again. Thanks for trying to help! Any other suggestions. It was great to get a response so quick! Thank you.
safe mode safemode with networking safe mode with command prompt last known good configuration and windows start normally, i tried them all but when i click on any of them i would just do nothing i stays on the same screen. any ideas!?
Did you try to do a F8 or F12 and safe mode start, or you can also start from last known good configuration too. Try that out and I hope it gets you up and running, If you need anymore help just write back here and we will see what we can do. thank you
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
You have Video Failure... As A Result Of A Faulty Nvidia Graphics Chip..
Look to See If Your Make/Model Is On HP's Extended Service Warranty, To Replace Your Motherboard At No Cost...
Hi, It sounds like the graphics chip is on its way out the only solution is to invest in a new laptop or look on places like ebay to buy a motherboard, you could probably find one from £10 to £100
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me [email protected]
on your display properties, switch windows to appear on your laptop. and do not connect your LCD when booting your PC. there is an option in display property that says extened your windows to this display... that is your LCD.
I dont get the last known good config option, only safe mode, safe mode with networking and start windows normally.
I'll select start normally, and it starts up to the vista welcome and just stays there.
Where can I get a startup disk to start from scratch?
any help would be great
Luis
