Question about Sony Ericsson Walkman W810i Cellular Phone
My screen flashes white and the phone wont turn on the computer dosent recognize it if plugged in with USB
  • 3 more comments
  • Anonymous Feb 08, 2008
    my screen flashes white and doesnt turn on
  • luvie24 Jun 04, 2008
    I have a sony ericcson w580. It wont turn on when usb card attach phone to computer a red light appears. computer says new device found but cannot install device. the phone refuse to turn on
  • benji14 Jul 30, 2008
    When eer i go to turn on my mobile phone ( 810i ) the screen just turns white and flashes about every 5 seconds. I really dont understand this ....
    Thanks
  • daryl422 Sep 03, 2008
    my phone does the same just flashes white on and off
  • Anonymous Oct 04, 2008
    i hate it when it does this too
K310i no network coverage please guide me solve the problem
Posted on Oct 21, 2008
Do ya press 2 and 5 on the phone or the computer
Posted on May 07, 2008
    President:
  • 1,017 Answers
To connect to a PC you need to install Sony Ericsson PC Suite. If you have installed PC Suite from the disc provided in the box with the phone, you need to update it to the latest version for your phone. http://www.sonyericsson.com/cws/support/products/softwaredownloads/w810i?cc=gb&lc=en
Try to get to the menu to do a factory settings reset. That might solve the screen problem.
Posted on Feb 08, 2008
  • Raysagem
    Raysagem Feb 08, 2008
    Phone not turning on, LED flash red when you press the on/off button, does your phone use a DCU-60 usb cable. Hopefully the following steps will help you out:
    THE FOLLOWING IS A SET OF INSTRUCTIONS FOR "REVIVING" YOUR SONY ERICSSON, THIS IS JUST A GUIDE ONLY AND I AM NOT RESPONSIBLE FOR ANY DAMAGED ENCOUNTERED. IF SYMPTOMS PERSIST THEN IT’S TIME TO SEE YOUR SONY ERICSSON AGENT OR REPAIRER.
    Remove the battery, SIM card and the memory stick from the phone and then replace the battery but DO NOT turn it on.
    2. If you're operating Windows XP or earlier use your PC suite however with Vista you might have to download Sony Ericsson's Update Service software from the Sony Ericsson website
    3. Then you'll have to download: WontanClient server, open it and allow the program to update. NOTE: you must leave the login box empty
    4. Plug the USB cable into the computer but not the phone
    5. Press start in Wontan
    6. Press 2 and 5 Simultaneously
    7. Plug your phone in and hopefully the phone will to reboot
    8. Take out the battery for a few minutes and now your phone is hopefully working again.
Its a software falt take it to a shop it should not be much to fix this as it has happened to me it cost me a fiver to do it; colinw
2 Suggested Answers
SOURCE: w810i
i have the same problem with my w810i when i press power button it just flashes white screen and nothing to do with that and it cannot power off unless you take out the battery. when plug it on usb with dcu-60 cable that came with bundle it did not recognized the phone what should i do to flash it.
Posted on Feb 12, 2008
Could not open the flash drive. i think the drivers is not loading
when you plug the usb dose the computer recognize it and gives you a pop up new device found.
if yes then right click on the my computer icon go to manage and go to diskmanagement and see the drive and its there but dosent have a drive letter on it just right click and say change or add drive letter and it will apear on the my computer .
if it dosent recognze it when you connect theneither your usb port is disabled or the flash drive have an issu
to be sure try to plug this device in other computer if it works over there then its your usb port blocked by anti virus you are using .
or the port is not working properly.
thanks
Dec 13, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My computer is not recognizing the drive when I plug it in.
Hi did you try in other computer if yes and still didnt work do you listen any noise on the hard drive .
another thing to do to be sure that the usb ports are working fine in your computer its not been disabled bu bios or an antivirus please plug a flash drive or other hard drive in the computer and see if it gets recognized if yes then your system dosent have any issue .and check the hard drive if it dosent get recognized in the other computer also then may be the partitiontable is corrupt or your iomega hard drive case has problem.
To remove data from your hard drive in the worse case u need to remove the hard drive and plug it to the system directly and check
Thanks
Dec 04, 2010 | Iomega (33090) 250 GB Hard Drive
K810i wont turn on
its a ghost
in YOUR PHONE
Sep 05, 2009 | Lands Phones
Blank Screen
1. Put your iphone in the dock, with the USB cable disconnected from your computer.
2. Make sure the phone is off (The only way I got the phone to turn off is to hold the power button + the home button for like 15 seconds)
3. Once you know the phone is off, press and hold the HOME button then plug in the USB cable to your computer, keep holding the HOME button the whole time.
4. Next it should put a Yellow Triangle on your iphone and it should say "connect to itunes".
5. Now restore your phone, and you should be GOOD TO GO!
Oct 16, 2008 | Apple iPhone Smartphone
Phillips go gear SA5125 mp3 player
Make sure you are using the original USB cable that came supplied with the GoGear, and then try the volume + method again. If the volume + method doesn't work, then there is a problem with the USB port recognziing the device being plugged in - or, the player was physically damaged.
May 29, 2008 | Philips SA5125/37 MP3 Player
Pny usb 2.0 flash drive memory stick
windows xp doesnt recognize in drive f, when i open and prompt it to format it says disk is copy right protected. I open it and there is a bunch of foreign mumbo jumbo that i can't delete
May 27, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
White screen
phone needs flashed take it to one of the little phone shops tht sell and buy mobiles
Jan 18, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Creative zen v plus
update to the latest firmware
Oct 28, 2007 | Creative Labs ZEN V Plus MP3 Player
Sony Ericsson Walkman W810i Cellular Phone Logo
455 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
