Question about Cell Phones
Speed dialing How do I put numbers into speed phone list then how do I use this faclity
  • 983 Answers
Which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Posted on Feb 07, 2008
How do I change the speed dial keys that are already programmed?
  1. In the phone, press the Menu key.
  2. Click View Speed Dial List.
  3. Click a contact or phone number.
  4. Perform one of the following actions:
    • To change the contact that is assigned to a speed dial key, click Edit. Click a new contact.
    • To assign the contact to a different speed dial key, click Move. Roll the trackball to move the contact to the new speed dial key. Click the trackball.
    • To delete the contact from the speed dial list, click Delete.
Jul 07, 2014 | Mitel Superset 4015 Corded Phone
How do you put speed dialing in a samsung GT-C3520
Here are the correct steps to set Speed Dial on Samsung CT3520.
1. Go to Menu
2. Click on Contacts
3. Once in Contacts Menu, click on the right arrow from the navigation function.
4. You will see Groups, Favourites as you keep clicking
5. In Favourites, you will see that No 1 is assigned to Voicemail, No 2, 3 and 4 can be set.
6. Click Assign
7. Contacts will open up, search contacts and click Add
8. Do this for other three contacts.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
How to put numbers into speed dial on a Sprint Rumor Reflex
Go to the contacts list. Hit more. Settings. Speed dial. tap a number and select the contct/phone number combo to call.
(Source: I literally just did this on a customers cell phone in best buy mobile)
Apr 07, 2012 | Cell Phones
How do I programm the Speed Dial on my 4406D+?
To program your Personal Speed Dial numbers, make a list of
your telephone numbers/extensions numbered 1 to 24, then:
Press an Intercom button + lift handset + dial #00 + dial # + list number (01 to 24) + dial *21 + the number you want to store + #*00.
To use Personal Speed Dial:
1: Press an Intercon button.
2: Press Feature (if you have programmed a "Feature" button) or #.
3: Dial the two-digit code (01 to 24).
Apr 27, 2010 | Avaya Merlin Magix 4406D+ Corded Phone
CECT KA08-how to set up speed dial?
Follow the following:
>Call Center at the bottom
>General call settings
>03 Speed dial
>Check that "enable speed dial" is on
Then
>02 Set number
>You will see a list of "empty"
>Touch on the one you want to assign a number
>Edit
>this takes you to your phone book
>Choose a name from your list and save it to your speed dial.
>To call the number from your speed dial list, click on the "Phone dial" icon, and hold the number down. For example, is the number 2 is home, hold 2 down until you see it dial and there you have it.
Hopes this helps
Jul 29, 2009 | Dual Electronics CECT P168 Cellular Phone
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Dec 22, 2008 | Nokia 6085 Cellular Phone
Setting up a speed dial
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Sep 16, 2007 | Kyocera K10 Royale Cellular Phone
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
327 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
