To clear the code, try the following:
1) Press Additional Functions 2) Press # to enter the service menu 3) Scroll over to select "#12 Clear" and press Set 4) Scroll over to select either "ERR" or "ALL" and press Set 5) The LCD should report "CLEAR OK". Cycle power on the device.
Since you listed error code E000, I assume you are talking about a Canon copier. The fuser assembly failed to heat up and the code needs to be reset in service mode. If the code cannot be reset , you need a new fuser or parts for the fuser unit. Always list the Brand and model to receive the most complete answer.
+ The thermistor has an open circuit or short curcuit
+ The heater has an open circut. The thermal fuse has blown
+ The power supply PCB has a fault
+ The engine controller PCB has a fault
To Fix Error code E000 of Canon LassetJet LBP-3300 printer, you can try the following:
+ Check connector of the fixing film unit
+ Replace the fixing film unit
+ Replace the power supply PCB
+ Replace the engine controller PCB
This is not a job for a novice. Get a service technician to service the unit.
The glow plug symbol is seen on diesel-powered engines, and it lights up to denote that the glow plugs are still warming up. Do not crank up the engine until this light goes away. However, if the light remains even when the car has been powered up, you may have a faulty glow plug.
Your printer show Error code E000 suggests the problem history has recognized all of these of the following error codes four moments: Error code E001;Code E002;Error E003. Printer Canon E000 error will be removed in the service mode.
Please try reset factory your canon printer..but if it still show error code E000 again ,you can try with a genuine fuser unit (reseting fuser unit). Good luck
Solution 3: Try this, atempt will clear canon E000 code in Service mode:
1.Press ADDITIONAL FUNCTIONS, #
2.Go to #7 Printer and Press OK
3.Go to #4 Printer Reset and Press OK
4.Yes = ( * )
The heating element in the fixing assembly (the hot rollers) has probably blown. It can also be caused by a faulty thermal sensor, or a circuit board, relay or DC Controller.
If you are not competant at repairing copiers, you should have a service technician fix this.
The error cannot be cleared until the cause of the fault has been rectified. This is a safety measure to prevent overheating problem and further damage. The technician must clear the error in 'Service Mode'
hi, check once again if it's E000-00-0081 code. i just looked in the service manual for that machine and there's no E000-00-0081 code. the only one pointing to E000 is this:
insufficent temperature rise of the fixing unit at power-on.
the one pointing to 0081 is:
p-sens-p when value of this position is lower than 255 it will indicate an error code: E020-0081.
you can check it in service mode which you can enter by pressing combination: *28*(star-28-star)
try specifing some more detailes, e.g. when it occurs
Your Fuser just went , Call you Canon independent or Authrized dealer, he will need to go into the simulation to reset this error. Usually E000 is either a fuser or fuser web error. I'll need to look this up in the service manual. most likely you'll need a quailify technician to reset this error code.
