Question about Zanussi FLA1001W Front Load Washer
Zanussi FLA 1001W washing machine - Programme selector dial
All the figures on the programme selctor dial of my Zanussi FLA 1001W washing machine have now worn off. Consequently I now have difficulty selecting the correct settings. Can I buy a new dial anywhere, or can I see a picture/drawing of the dial so that I can remark the settings on my own ?
  • 1 more comment
  • Anonymous Jun 15, 2008
    user manual
  • Anonymous Jul 15, 2008
    I looked in the Manuel no identification in book. Have emailed Customer Care at Zanussi today. need to know where the L and J should be on the dile.
  • Anonymous Mar 27, 2014
    Dial just keeps turning and not setting actual selection
    President:
  • 1,462 Answers
You can buy a new indicator as a spare - quite cheap. best souyrce would be service force - assuming you are in uk, its in the phone book
Posted on Jun 30, 2008
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Err code displayed and fails start
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Zanussi washing machine error code e80
An error has occurred with reading the programme selector control. This can be resolved simply by turning it to "0" and selecting a programme again. If this doesn't cure the problem you may need to seek professional help.
Nov 19, 2011 | Zanussi ZWF1430W Front Load Washer
I'd like to know the key sequence I need to press to be able to self-diagnose the problem I've got with my zanussi washing machine. ZWF1640.
To display Error Code:
Move Programme Selector to the Off postion.
Press the 2 buttons on the right and turn the selector 1 position clockwise and hold the 2 buttons for about 5 seconds until all the lights are flashing. Release buttons and turn the selector to the 10th position. The Error Code will be displayed.
Note the code then turn the selector to off ,then on,then off again.
Feb 28, 2010 | Zanussi ZWF1440 Front Load Washer
Zanussi FLA 1001W does NOT spin
You need to check the brushes in the motor first, replace if less than 3 or 4mm long.
If brushes o/k, then could be a module or motor problem, apart from the belt being broken or worn of course.
Hope this helps.
Jan 23, 2010 | Zanussi FLA1001W Front Load Washer
Programme not going through cycle
Hi does the machine fill with water? If the machine programme dial does not move then it is more than likely to be the heat cycle that needs looking at!
If you are local to me then we can arrange a visit to repair.
Good luck.............................
Dec 28, 2008 | Hotpoint WMA54 Front Load Washer
Zanussi Electrolux FX 1265 W washing machine wont work
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
Sep 20, 2008 | Washing Machines
Programme Selector Dial Numbers
Hi Petal,
I looked in the website Washdoctor gave you and found a user's manual for your washing machine at this link: http://www.serviceforce.co.uk/pdfs/U23063.pdf
There's an diagram of the control panel on page 6.
I hope this helps!
Dec 01, 2007 | Zanussi F1245W Front Load Washer
Wash but no spin
1st of all is there a spin cancel buuton on this machine and has it been activated, or is there a spin speed selector knob and has it been turned down...is inner drum easily turned by hand.if it is ok then belt tension could be suspect (tighten)im sure there is an out of load balance detection circuit on the main circuit board....also is it draining ok because it wont spin until it cant dectect low or no water prior to final spin.....also if it has a programme dial the select a spin programme on another section of selector dial.........hope this is of some help...
May 08, 2007 | Zanussi F1045W Front Load Washer
Zanussi FLA1001W Front Load Washer Logo
300 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
