Question about Vestax Pmc07pro DJ Mixer System
AC adapter problem
OK few days ago i have break the adapter in the hall of the mixer.it s brake inside so no solution now to plug my mixer.can you help me...thanks
  • 1 more comment
  • kapsee Feb 07, 2008
    i have break the small thing in the hole where you put the adapter .the thing stay inside the adapter .
    the ouput in the mixer is broken so i need to refix something in the mixer
    ok thank to everyone for your help
  • 749 Answers
Buy a new adapter with the same brand or a compatible one, that has the same output voltage and ampere, also check the output jacks it must be the same as on the broken adapter.
Goodluck... Fixya me...
Posted on Feb 07, 2008
Brake lights, hazadrslights dont work and none of my guages, keeps blowing fuse for gauges.ac stopped blowing cold and alt dont charge. breaks and hazard went then the rest two days ago
first there is many separate circuit in your question
do you have a trailer plug in rear of your truck
you might find your hazard and brake fuse blown short to ground
Oct 09, 2013 | 1997 GMC Jimmy
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works,...
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
My wii was working a few days ago then I tried to turn it on today and it will not come on. I tried plugging it in to different outlets but it still will not come on. No lights will come on either.
hello,
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
The AC adapter must remain unplugged at both ends for a full 2 minutes.
After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Try to find someone with a Wii.. not that hard everyone has one. See if they will let you use the power cord.
test the cord and if that doesn't you know its inside the Wii.
Then, their are fuses inside the console one of them my have blown.You need a special screw driver.
Hope this will help..
May 31, 2010 | Nintendo Wii Console
Dell laptop won't restart. No lights coming on. No power when hooked up to AC outlet with battery in it. What do I do? It did the same thing a few days ago,then I removed the battery,pluged it in and it...
if no sing of power when you plug in i would check AC adapter if is there voltage on it,
adapter plug could be interrupt conection (if yes you should change it)
- try to run it without battery
if it not battery or adapter problem i would go to restart BIOS setting to default, (when u finnally run computer) press F2 or esc when u turning on computer it will turn u to bios.
Hope it help
Mar 02, 2010 | Computers & Internet
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 08, 2009 | Nintendo Wii Console
Few months ago I started having issues with the ac adapter it did not provided power to the unit, if you unplug and plug it again from the power cable it worked, until one day just stop. I purchased one in...
Apparently, either the AC adapter isn't compatible (check the voltages and power ratings) or you have a battery charger issue. If you're sure the adapter is OK, then the battery might wrongly report a full charge at a higher voltage than the AC adapter.
So when the battery is plugged in, it will always preempt the AC adapter - possibly even shutting it down - except that, having almost no power left, it will also force the computer itself to shut down.
What might have happened is that the faulty AC adapter actually damaged the battery. I'd suggest checking with another battery if any is available, and not to use both together lest the battery now damage the new adapter. But first of all, check the power ratings and polarity on the adapter against the old one and whatever is indicated (usually) on the PC underside, just to be sure.
Oct 27, 2009 | Gateway 6022GZ Notebook
Notebook won't power up with AC Adapter plugged in
your header for adaptor has worn out, or your AC adaptor had gone out. you can buy a UNIVERSAL adaptor which will fit any laptop from Newegg, fry's, office stores, etc. is a new adaptor does not work then you have to replace inside header. you can try taking a small knife and using it rub around inside to try to "revive" contacts. it is an expensive replacement cost
Apr 26, 2009 | Toshiba Satellite A15-S157 Notebook
My mixer wont start
First of all plug another appliance into the receptacle to make sure you have power there. If you don't have power at that receptacle you have blown a fuse or tripped a circuit breaker. good luck
Jan 16, 2009 | KitchenAid K45SS Classic Stand Mixer
Today mixer stopped while mixing.
OK, you mentioned everything except the brand. I found on some models of Sunbeam mixers that the speed governor would fail due to the control knob screw being loose.
On that particular model, the screw is behind a stick-on label in the center of the knob. Peel off the label and make sure the screw is tight.
If your mixer isn't a Sunbeam, please advise.
Mar 23, 2008 | KitchenAid KP26M1X Stand Mixer
Won't turn on
Ouch! You can't use an AC adapter with any battery-operated equipment you choose to just because the plug fits physically. The A70 requires 5-6 volts, and a Pavilion adapter typically puts out 18 volts. You most probably blew out your Canon's power supply within a few seconds, unless it's fused somehow. Next stop: tech support/repair shop/camera cemetery. Sorry.
Aug 23, 2006 | Canon PowerShot A70 Digital Camera
Vestax Pmc07pro DJ Mixer System Logo
232 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
