Question about Car Audio & Video
Radio code for Volvo V70
I recently had to recharge my battery and need to put in my code for the radio to come on.  The only option I get is OFF and I can't get the option for the word CODE.  Is there another way for me to get the word CODE so I can put in my 4 digit number?
  • 7 more comments
  • pinkins777 Apr 02, 2008
    I have the code for my Volvo. I need the procedure for making the CODE reappear; right now it is showing OFF. I put the key in the 1 position, but OFF never disappeared (I waited about 2 hours). Is there a trick to make the word CODE reappear without waiting the 2 hours?
  • caronsusanne Apr 20, 2008
    My husband put the radio from his s90 into my v70.  The battery went dead and now the radio is showing off. How do i fix it?  I took the fuse out for about 1 minute and then put it back in and off is still there.  How can I fix this?
    Thank you
  • emk1234 Apr 27, 2008
    unlocking code for my V70XC Volvo V70 YVILZ56DOY2640794. i lost the code for it..pls kindly send it to me.
    thanks
  • Anonymous Jun 19, 2008
    I keep getting the OFF displayed on the radio what to do?
  • Anonymous Aug 01, 2008
    my radio shows off on the screen.i need it shows code.i already tried waiting 2 hours ignition on 1th position.it did not work.
    thanks
  • Anonymous Sep 03, 2008
    how to get off out of radio
  • adamweldy Nov 26, 2008
    The radio in my V70 reads "OFF". I have the code and waited 2 hrs with car on and still no change.
  • Anonymous Dec 18, 2008
    I have the exact same problem on my 99 S70. I can't find my code.
  • Anonymous Mar 19, 2009
    but it cost 250 SEK. -So i google the code :)
I called the local dealer with my VIN (you can see it looking through the windshield) and they gave me the code.
Posted on Mar 25, 2008
Volvo V70 fuse in slot 7 Radio/Amplifier keeps blowing when trying insert new fuse
red is hot and black is ground never switch the two around , put them back the way they where and if your battery is going dead because of to much voltage drawn then you need to up the battery size and alternator .
Feb 15, 2013 | 2000 Volvo V70
My 2000 Volvo v70 xc's radio is not working. I
Your radio has been replaced, not uncommon for that year and the SC series of radios. The dealer will need to remove the radio (real easy to do) and has to get 2 numbers from the tag on top and query them through the Volvo DMS system. Note that if you enter the wrong code 3 times the radio will say OFF and you will have to leave the key in position 1 for up to 4 hours till the radio anti-theft resets and you can try again.
Jan 02, 2013 | Cars & Trucks
My 2000 v70 xc had the battery disconnected and the factory stereo needs a four digit code to work again. i got the car used and need to know how to obtain that code from volvo. there is no dealer nearby
Sadly:
There is only 2 options.
1. Your radio code is in your paperwork for your car (Its on a hard plastic card) Find it.
2. Take your registration to Vin and Ser Number for your radio to your local dealer.
These codes are a guarded secret and no one code fits all.
Hope this tip helps guide you in the correct direction to solve this problem.
R/
David
Mar 13, 2010 | 2000 Volvo V70
Need a radio antitheft code for a 1999 volvo v70xc
The code should be written in your user manual, if not, you will have to contact a Volvo Dealer. This option is placed in vehicle radios to deter theft and render the radio useless if stolen. Thanks for using FixYa.
Feb 11, 2010 | 1999 Volvo V70
Batery discorneted lost radio code on my volvo v70 no luck from volvo as car 15 years old
Hi:
The only way to get the radio code is at a dealer, and often you have to have the serial number of the radio, the VIN number of the car, and go to the service department. This is an anti theft preventative, and keeps theives from reselling stolen radios. If you have been to a Volvo dealer and done all I suggested above, then your only option is an aftermarket radio .
Feb 09, 2010 | 1998 Volvo V70
Radio code 1998 volvo v70
your going to have to call up your local volvo dealer and give them your vin number and they can look it up for you. You can try using radio-code.com but i wouldnt recomend it. Your best bet is calling your local volvo dealer and they will help you out.
Feb 21, 2009 | 1998 Volvo V70
Problems with radio code
Your radio is now in "off" mode. To get it back to "code" mode you need to have power to the radio for 2 hours. This can be accomplished by either driving the car for 2 hours, or putting the key into position 1 on the ignition, but make sure to turn off the fan as it will drain the battery in 2 hours. Once you have "code" back you can enter the 4 digit radio code. Caution, many of these radios have been replaced so the code that the dealer gives you may be wrong. If entered and it comes back "EEEEEE" that means it is the wrong code. The radio must be pulled and get the factory serial number from the top of the unit.
Hope this helps!
Dec 26, 2008 | 2001 Volvo V70
Have Volvo v70 battery has been dissconected and radio needs code
just call nearby volvo with your vin number and they will give you the code.
Oct 18, 2008 | 2003 Volvo S40
1999 Volvo Radio Code problem
a radio repair shop will recode it for about £15 $25
Sep 17, 2008 | 1998 Volvo V70
Car Audio & Video Logo
2,168 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
