I have a blank screen on startup. The fan and everything starts but suddenly the screen goes blank. The monitor indicates it is working and I switched it just in case but no improvement. I have restarted several times hitting F11 but no good, what next?
If you are sure that you have tried with a working monitor, then it means that even though you can see the fan working, the PC is not actually booting. Now try changing the memory with a working one. If the problem persists, try replacing your video card with a working one. You should be okay.
If not, then you would have to go further to check your processor and then the main board if necessary. All the best.
Your system might have been corrupted or you have a damaged boot record, can you try booting into safe mode? or you should check if your devices has been detected to ensure that theres no problem with the memory itself.
Ur RAM is corrupt or
ur VGA driver is corrupt...
try this
pull out all power and power cables
and keep pressing the power on button on PC for some time with NO POWER and put back the power and switch on
