Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch shu5302uc - overfill pump wont quit running
Cleaned out my filter in the bottom and when I turned it back on it started to drain and wont stop. All I think I have to do is reset the system. Need help.
  • 1 more comment
  • spasecowboy Feb 07, 2008
    I have unpluged the unit from the wall for over 10 min. and still nothing
  • Hittman Feb 27, 2008
    Helo please help if you can. I have a BOSCH SHU5305UC. I had a clog in the sink drain and the water backed up into the washer. I fixed the clog and reset the cycle turned the machine back on the water pumped out but the motor keeps running and dosen't fill with water it worked just fine pryor to this can someone please help me. Thank you
    I did unplug it and the motor runs but still dosen't fill
I had the same problem and I had to take the unit out of it's cabinetand tip it forward to get the water out of the bottom pan I let it set on it's face for about 20 min. put it together and it is back in working order hope this helps
Posted on Feb 27, 2008
  • 770 Answers
Have you tried to shut down the breaker for the unit and turn it back on ??
Posted on Feb 07, 2008
Bosch classixx dishwasher wont drain
Ive had this happen on mine too. remove the filters in the bottom. squirt washing up liquid into the space-- liberally dont be shy!
Boil pans of water, boil the kettle. pour water into the space where the filters normally are. Fill the base of the dishwasher completely. Next close the door and repeatedly use the Reset feature. Eventually the pump will clear and kick back into life. Its a build up of fats, and sludge that causes the pump to appear to seize--the washing up liquid and boiling water see to that.
Feb 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
SHU5302UC dishwasher will not spray or pump.
Pump motor would be where I would start. It could be something that has the impellers locked up so they wont turn or the motor could be bad
Jan 28, 2010 | Bosch 23 in. SHU5302UC Built-in Dishwasher
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
F04 error message on a bosch exxcel 1400 washing machine, then the water wont drain away
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Sep 26, 2009 | Washing Machines
Leaks, doesnt drain properly and cloudy film on glasses
u have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
Sep 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch DLX series didn't drain, now no power
I had a Bosch DLX series dishwasher that had multiple problems.
First, it had greyish water in the bottom and pushing the power button did not turn on any lights. it had mostly finished a cycle, but not quite. my first thought was to clean it out. i sponged out all the water and removed and cleaned out the filters from the bottom which were all quite nasty. i found food, tiny bones, etc. I cleaned it out and that did nothing but was still probably the cause of the problem. I called Bosch tech support and asked about areset switch. There is none. They told me to switch off the circuit breaker for 30 MINUTES to reset everything. I did that which did not fix the problem.
I then examined the connector wires (connecting the electric to my house wiring) which are in the front under the kick plate, and discovered that they had MELTED! The wiring supplied by Bosch was stranded wire, and my home wiring is solid core. i trimmed the burnt stuff and reconnected it with new wire nuts. if this happens again i plan to disassemble the dishwasher's electric and replace the stranded wire with the good stuff.
That restored the electric and the lights and display. i then ran a test cycle and it seemed to just hum. my guess after googling a bit was that the float was stuck in the up position, and it was trying to drain. This site http://www.applianceaid.com/boschDW.html told me how to run the test mode.
"To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button."
The test mode tested out all functions which I think wound up reseting the float switch which actually fixed the rest of it.
Sep 01, 2008 | Dishwashers
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
128 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
