Question about Fuji FinePix Z100fd Digital Camera
Frame no full
Hi i was wondering if you can help me, everytime i turn on my camera it tells me "!!frame no.full" and wont let me take any pictures!!! what can i do to stop this from happening???
  • 983 Answers
Try emptying the memory card & phone memory then give try ... if same problem persists then may the software of the camera may be corrupted .... you give for installing the software in the show room where you purchased or ur model named show room...
they may charge some 300 to 500...
Posted on Feb 07, 2008
Hi, I was taking pictures with my camera and I turned the handle to get to the next picture and the button we press to open the shutter (capture the picture) I can push it but it wont click. Please tell me...
Sounds like the shutter has not fully cocked, which often happens when you get to the end of a film and the film advance won't move on a full frame. Try the film rewind crank(gently). If it is not able to turn either way, then you have used up a film and have to rewind it and remove it from the camera. You will then be able to advance the film wind lever to finish cocking the shutter and it will fire as normal.
Oct 18, 2010 | Nikon FE 35mm SLR Camera
My camera is saying 'Frame No Full' and wont let me take photos?
Do the following procedure to fix this problem.Save all pictures to your computer turn camera on, press the menu/ok button, select Setup, press ok. Select frame number and change frame No. to renew, press ok.
  • Leave Setup.
  • Press the menu/ok button, select Setup, press ok again.
  • Select Format, press ok / ok until the card is formatted.
  • Now the counter should start over with 100.0001 again.
  • Set frame no. back to Cont. to avoid to many images with the same filename.
Thank you !!
May 30, 2010 | Fuji Finepix Z20fd Digital Camera
Won't let me take pics, says FRAME NO. FULL
Your Counter has reached 999.999
Here's what you do.
Make sure you have no pictures on your card to start with.
Place the card in the camera and turn it on.
Press "Menu" and go to the "Set" menu and select "Format". This will wipe your card completely clean. When this is done select "Frame No" in the set up menu and set it to "Renew".
Now come out of the menu options and take a picture.
When you review your picture the counter should read 100.001
Now go back to the set up menu and reselect "Frame no." and set to continuous ("Cont.")
Happy snapping
Oct 16, 2009 | Fuji Cameras
Come up with frame number full
The problem is ther internal memory is full or your external card is full and you have to reformat the card. Then you should be able to use the camera .
Apr 10, 2009 | Cameras
Every time I turn on my camera it says ''FRAME NO. FULL''
Hello, it will help:
go to settings menu, then look for FRAME NO. setting. Set it to RENEW. It should do the trick.
It happens because the internal picture counter has reached its limit and you have to reset it to zero.
Nov 22, 2008 | Fuji FinePix A600 Digital Camera
"Frame NO. Full"
Try going in to the "setup" menu and change the frame numbering from "continuous" to "renew", if it is not already done. Sounds like you are on the continuous setting which keeps adding numbers, even though you've erased many. Going to renew starts the numbering over so it keeps reusing previous numbers.
Jul 06, 2008 | Fuji FinePix Z100fd Digital Camera
Frame number full
when i turn on the camera I get a frame no. full, I tried formating the memory card to no avail. I can't take a picture with this error
Jun 16, 2008 | Cameras
Fuji finepix s7000
Per the owner's manual:
  1. Insert a formatted media into the camera.
  2. Set "RENEW" as the FRAME NO. setting in the SET-UP menu.
  3. Start taking pictures. (the frame numbers start from "100-0001".)
  4. Set "CONT." as the FRAME NO. setting in the SET-UP menu.
Then you're done. We just did this on ours and now we're ready to go. God Bless.
Jun 05, 2008 | Fuji FinePix S7000 Digital Camera
Finepix s700
I had the same problem. Once it said "Memory Full" there's no way to get rid of it how much you try to recover, format the card, reset the camera with no avail. I had thought the camera was out of order. Then googled around and come across with this workaround. When nothing else works for you just take out the memory card. Take a picture to the internal memory of the camera and then insert the card. Voila!! you can enjoy our camera. I guess this is a software bug. The camera can not reset the memory card full flag before you take a picture to the internal memory.
I hope this helps.
Mar 20, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix Z100fd Digital Camera Logo
146 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
