HP PRINTER i have a printer that doesn't print it's a dual catridge i'm assuming one for tricolor and the other b/w.i'm not sure .i purchase a dual pack of cartridges left side snaps right end the right side doesn't snap into place. it trys to print but nothing coming out on the paper.there is a place for a port type cable.maybe that's the reason it's not printing,also the catridge that came out of it # is 51649G the ones i purchase # is 51649A.i was told that the A and G letter didn't matter, obviously it does because it doesn't sit and snap on the right side,can you help and maybe send me a manual.thanks!
Hi, the HP 49 is a color cartridge, it goes on the left cradle, the other cartridge, maybe a HP 29 goes in the right cradle if you have a HP Deskjet 600 series (This goes from 610 to 692).
Posted on Feb 07, 2008
I have a new HP TriColor Cartridge and my printer will not print anything except black. Also have a flashingterdrop light on left side. What is the cure?
Hi. it actually sounds like something is not contacting with the cartridge. remove the cartridge and inspect the contacts inside the printer, the ones that touch the front of the colour cartridge, for dry ink, dirt or dust, use a cotton bud dipped in boiling hot water to remove any ink on the contacts, make sure the printer is off before doing this any make sure no water is left inside when you switch it back on.
I hope this helpsRegards
Grant
Nov 11, 2011 | HP DeskJet 6540 InkJet Printer
My HP Officejet Pro L7650 printer says "Cannot
Hi
Firstly you should check if there is any covering on the ink nozzles
Did you try to allign the print catridges after you changed the same.
Take out the catridges and clean it with a piece of cloth again put it back and check
if still it doesn't work
If you have done it perform a semi full reset:-
Unplug the power cable at the back of the printer
Press and hold down the (#) and the (6) key together pplug in back the power cable
Leave the keys it should say on the screen semi-nvm reset if it doesn't says so its not done properly .. try to do it once again after that it should align the catridges automatically
This should solve your problem if not try with a different catridge
Aug 24, 2011 | HP Officejet Pro L7650 Printer
After refilling the cartridge of hp 3745 printer i reinstalled it but the printer doesn't detect it, printer light only blinks
On refiilling catrdige may have some nozzle detection problem,so you have to purchase one new catridge and install,it will work.(check put the catridge number)
Jun 06, 2011 | HP DeskJet 3745 Printer
Magenta in tricolor not flowing
unplug printer cables, replug in
take cartridges out, put back in making sure sure nothing is obstructing the ink dispensary on the cartridges and that they're clean
look in the printer where the cartridges go, making sure nothing is blocking the ink
check the rollers to make sure no paper is caught inside the printer
turn on printer and try this
hope this works and good luck
Apr 30, 2010 | HP DeskJet 810c InkJet Printer
The following print cartridge is not intended for
Take it back, might be the wrong one, or manufacturer's defect?
Mar 14, 2010 | HP Office Equipment & Supplies
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
Oct 28, 2009 | HP PSC 750 All-In-One InkJet Printer
Use of 852 and 855 cartridge in hp 6210 officejet printer
This quite often happens with CLONE cartridges and happens very infrequent with original cartridges.
The cause is the ink level chip used in clones is quite often a very cheap chinese copy and very prone to failure or misalignment
Either way take them back and get them changed is my advice
Aug 17, 2009 | HP Office Equipment & Supplies
Incompatible print catridge
You have to purchase compatible catrige.
Thanks, GF
Apr 27, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Carriage stalled on hp psc 1200 all in one printer
I suppose never use a refilled catridge need to check the catridge for any damage and also check the sensor of the printer , incase the sensor is damaged you hear a loud noise.
Dec 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
