Canon FAX-L200 Plain Paper Laser
Problem for Canon FAX-L200 Plain Paper Laser
I want to scan then send instead of scanning whilst sending
By Cakemaster on Feb 07, 2008
We have several Canon L200 fax machines. I am new to setting up faxes and just have the manual to work from. I have just been setting one up for use in a different location. Our other L200 faxes scan the document straight through, then start dialing to send. The one I am setting up is scanning very slowly as it is sending.
Could you tell me how I change the settings to scan the document straight through, then start dialing to send for all documents.
Comments:
Feb 08, 2008
- Thanks for explaining the 2 different ways of sending. I want to use memory sending.
The fax in question had no documents queued, had plenty of paper and toner, and nothing waiting to print, but was still using real time.
Is there a setting I can change to always use memory sending? Sorry if this is a stupid question but I'm new to the world of faxes.
Feb 29, 2008
- Thsnks for your help. Someone else had a look at the fax machine and found that superfine was set. This was changed and now faxes are going at normal speed.
Solution #1
posted on Feb 07, 2008
Somewhat Helpful)
Logjam
Rank: Wiz
Rating: 83%, 130 votes
There are 2 methods of sending 1. Through memory, in which the machine scans the document then sends when all pages have been scanned. 2. In real time, in which the document is placed in the ready mode and the line monitor or handset is used to dial the number. In this case the document is not scanned until a response is heard from the other machine.
However, in the case of the memory being full, either of documents in the queue or if there are documents waiting to be printed (because of no toner or no paper) then the machine will not allow sending from memory.
Comments:
Feb 08, 2008
- As far as I know, there is no setting for forced manual transmit. Therefore it can only be a memory problem. Check to see there is no documents stored in memory. The simple way is to check the display. Otherwise use the memory reference button and press set. This will print out a list of documents stored in memory. However, what I want you to do is tell me the exact procedure you are using to send your fax documents. Lets go from there
Feb 29, 2008
- The reason to check display and any lights, is for that reason. The display will help to see how much you have stored in memory and the lihts will let you know what settings you have. Glad you got it going
Was this helpful?
Yes
No
Popular Solutions for Canon FAX-L200 Plain Paper
Questions and Unsolved Problems for Canon FAX-L200 Plain Paper
Do you recommend Canon FAX-L200 Plain Paper Laser?
Answer
Answer
MP350 Fax machine seems to be stuck on autodial. In addition the memory light will not go off, but... (More)
Answer
1120L Manual Request
Answer
I have a Philips Magic 5 Primo and there is a message on the screen saying Card Expired / Replace... (More)
Answer
Dear Sirs, I have a brother mfc 8840dn the display tells me check original and there is no original... (More)
Answer
I am constantly getting this message "Incomplete reception"! I can send fax, but i can't... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Fax Machines Experts
Top Copier & Fax Repairmen
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
