LG Flatron L1720P Loses Display
My 1720P is approx. 3 yrs old. After about 10 min operation the display suddenly goes black. I hear a small click when that happens. I can still see a slight "ghost" t the display. If I turn the monitor off & wait a few minutes the display returns, but then will go dark again after several minutes. This process repeats w/ the ever shortening intervals. Any ideas as to the problem & whether it's a reasonable ($$-wise) fix? --It just happened adain!
  • 1 more comment
  • kvanoort May 14, 2008
    From the description in the previous posting, it sounds almost exactly like the problem I'm experiencing with my LF Flatron L1720P. Now, the monitor doesn't even turn on. I just hear the clicking sound but nothing happens.
  • Anonymous Jul 22, 2008
    Monitor is black but the computer is working. I get a blue blinking light on the monitor power on/off switch. Sometimes the blinking alternates between blue and yellow. Can't get a picture back.
  • tclbbs_onlin Dec 23, 2008
    I have this problem, when this monitor is left on when the computer is turned off and left off more then a few minutes.
No tiene brillo
Posted on Mar 28, 2008
The backlight inverter board is defective or a high voltage cable going from the inverter output to the lamps is damaged or touching ground.
Posted on Feb 07, 2008
LG Flatron l1515s which is giving Out of Range 64.0kHz / 60Hz and can not even give setup menu. Please help.
This is not a setting on your monitor. It is a setting on your operating system. The display settings needs to be set to a 60Hz refresh rate.
Hook up your old monitor and right click on desktop --> properties --> and then to display and advanced settings. You can then set it to proper refresh rate and plug the new monitor in.
Mar 28, 2011 | LG Flatron L1515S 15" LCD Monitor
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED...
Oct 14, 2010 | LG L1730S 17" LCD Monitor
Electronic display was flashing LE. Unable to open front load visible water. Tried to restart...unable. What is your best solution to open front and get washer working again? washer is...
Waht make? Model?
Sounds like an LG
You might want to unplug the unit for 10 min -then plug it back in and then power up , then press pause.
LE- could be a motor sensor, main board issue - wiring issue
Affordable Appliance repair
Orange County, CA.
Aug 22, 2009 | Washing Machines
LG G4011 screen backlit, no images
I contacted manufacturer who said it would have to be sent in to be repaired- would take 10-14 business days and cost $35-$95. I'm replacing it.
Feb 12, 2009 | LG G4011 Cellular Phone
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Hooked up a used 17" LG Flatron L1720P flat Panel. When I turn it on it says Power Saving Analog Mode and goes black, no instructions with it.
Make sure your power cables are connected properly. Sounds like it's not getting any video data from the graphics card.
If it is not your graphics card, It could be a dead monitor.
Feb 09, 2008 | Computers & Internet
Digital power saving mode
Are you sure someone hasn't changed the power setting in windows. I've seen similar tricks pulled by so called mates. :-) If windows is OK then check the manual for the monitor and if you still can't crack it take it for a ride to the repair shop. It is under warranty after all. BMW
Jun 03, 2006 | LG 1720B 17" LCD Monitor
Computers & Internet Logo
1,442 people viewed this question
David Payne
David Payne
