Question about AEG Lavamat 88840 Front Load Washer
Please help I own an AEG 6955 sensorlogic washing machine. This morning I did my laundry, but an error occurred at the end of the program: F9. My laundry was ready, there was no water left in the machine (or under it..) and it was as dry as always (I had heard the machine rotate). My manual only mentions F1 and F2 in case of problems. I tried to reset, but that didn't work. I took the power of, checked water supply and filter, but that didn't word either. I bought this machine in '97, and it worked perfect until now. Is it worth repairing, and what could be the problem?
Problem C9
Posted on Sep 26, 2011
I believe F9 is the error code telling you to replace the carbon brushes on the motor. Had the same thing on m ine 18 mths ago
Posted on May 27, 2008
    Master:
    Sergeant:
  • 440 Answers
Your machine is draining too slowly. When it initiates a drain cycle, the water level switch is sensing the water level is still too high after 60 seconds so the computerplease help - 1.gif stops and generates this fault code.
Here are the things to check;
* Check the drain hose and make sure it is not plugged or inked.
* Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
* Check/Clean Drain Pump Filter of foreign objects
* Check for Drain Pump Failure
* Check the Inlet Valve for proper shut off
* Check the Pressure switch for proper operation
Posted on Feb 07, 2008
  • nick helpap
    nick helpap Feb 07, 2008
    Are you using HE rated detergent? You MUST use HE (high efficiency) rated detergent in this washer
2 Suggested Answers
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Posted on Jun 12, 2009
My wash-machine, AEG oko lavamat 6955, is blinking at the 1500 and 900 buttons, and is showing the code "F9" and the door will not open. How do I fix this? And if I must have a specalist to...
to clear the error code: whilst holding the pre wash and short wash buttons in together turn the control knob from off to gentle spin, this will clear the fault code and run a LED test. (if all goes weel) F9 means carbon brushes need to be replaced
Nov 06, 2017 | AEG Washing Machines
I have a AEG lavamat 6955 sensorlogic front loader I had the motor changed 5 years ago. The washing machine still works but the drum is tight and does not turn. Even when the machine is off. It is...
Could be that the Inner Drum Spindle is broken, this is a 3 arm spider-ish bracket that holds the inner drum. To test this theory, see if you can lift the inner drum up & down from the door side, you will be able to feel if it is broken.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | AEG L86800 Front Load Washer
I have an AEG 6955 washing maching about 14 years old. Recently the program has stopped on many occasions with code F1 usually on first fill. Other times it works OK. The manual says this is no water....
Yes changeing the valve will fix it . around £30. On one occaision only I have come across the detergent dispensor top being blocked up enough to slow down the fill. on your machine it allows 5mins if this is exceeded F1 is displayed and prog stopped.
Nov 15, 2010 | AEG Lavamat 88840 Front Load Washer
Aeg oko lavamat 6555 cannot open door no response to buttons F9 flashing
Hi
Error code F9 means an error with motor or motor tacho failure. Try resetting the error by pressing quick and prewashing buttons together while turning the knob to gentle spin. All LED's will glow, now turn the knob back to Off and the machine should work. Hope this helps... Please post back for any further assistance.
Daniel
Aug 29, 2010 | Washing Machines
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG lavamat 6955 showing F9 on display panel
unplong machine and restart it .eamonn eire thank you
Jan 26, 2008 | AEG Lavamat 88840 Front Load Washer
Lavamat 6955 sensorlogic - carries on filling until water overflows from soap tray
fault f1 is slow or no cold fill. this fault code with overfill points to: air chamber blocked with sludge hose from air chamber to pressure stat blocked or split pressure stat faulty of these the first is the most likely
Dec 12, 2006 | AEG Lavamat 88840 Front Load Washer
AEG Lavamat 88840 Front Load Washer Logo
473 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
