Konica 4155 - J16 Paper Jam
I have a Konica 4155 copier that is giving a J16 paper jam code but there is no paper jammed. I do not see anything obstructing its path so do I need to clean the rollers or is it a sensor or something?
First, check if the paper loaded is matched with the copier settings.
If that doesn't solve the problem, carefully check the paper path sensors.
Posted on Feb 07, 2008
Consistent paper jam on konica minolta bizhub c451e
Please look the jam code, then only b easy to provide solution.
To check Jam code follow these steps.
UTILITY-METER COUNT
STOP 00 STOP 01
COUNTER
JAM HISTORY
Here you will find Jam code E.g J2202 like that.
Post again with jam code, I will give u solution
Dec 23, 2016 | Konica Minolta bizhub Office Equipment &...
How can I reset error code J16 on Konica 1312
Its a jam code remove the paper if not paper the senor for that section was damaged. Have tech replace it, check the acturator also might be missed place.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 16, 2016 | Konica Office Equipment & Supplies
How to clear paper jam 11 paper is cleared but still indicates that its a jam
Then properly the sensor near the jam had it accurator jammed so the copier thinks there is still a paper there. or you mite have paper dust or dust blocking the sensor. Could also be a bad sensor worst case bad main board.
Aug 14, 2014 | Konica Minolta bizhub Office Equipment &...
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
After paper jam printer displays error light and will not function
1. Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
2. Step 2
Turn off the printer.
3. Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
4. Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
5. Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
6. Step 6
jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
7. Step 7
jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.co.uk/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though.
8. Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
9. Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Mar 03, 2010 | Konica Minolta magicolor 2500 Printer
Removed paper after paper jam and have opened all the doors to check everything, however it still reads 'switchback jam open front cover up scanner unit'
  • Step 1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  • Step 2 Turn off the printer.
  • Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • Step 6266_a1.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_b1.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • Step 7266_a2.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_a2.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  • Feb 19, 2010 | Konica Minolta Magicolor 4695MF All-In-One...
    Screen says paper jam, can't find anything
    close properly your paper jam cover at the back of your printer down side. if not clean and check the sensor for paper jam.
    May 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Paper jam 11
    Step1
    Step
    Step
    Step
    Step
    5
    Step
    6
    Step
    7
    Step
    8
    Step
    9
    Nov 07, 2008 | Copystar CS-1815 Printer
    Unable to open to remove paper jam
    Step1
    Step
    Step
    Step
    Step
    5
    Step
    6
    Step
    7
    Step
    8
    Step
    9
    Sep 23, 2008 | Canon PC1061 Copier
    96 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
