Question about Friedrich QuietMaster Deluxe RS12L10 Air Conditioner
The water isn't go out
My air conditioner tha water not exit.
  • georgia1405 Jun 02, 2008
    The warter is draining out of my AC. It isn't tilted too much, it's more like the hole in the window cage where the water is supposed to drain doesn't match up with whatever is in the actual unit. Is there supposed to be a hole there? If not how does the water drain?
    Master:
    Sergeant:
  • 462 Answers
Dear miguel_5
Check the position of the ac if it is tilted too much on the inside then that could be one reason for water not flowing out other reason could be due to dust particles blocking inside.
Posted on Feb 07, 2008
Where is water exit
window units have a slinger ring on condensor fan. it throws the water onto the condensor and evaporates.
Jul 29, 2015 | Daewoo DWC-056CL Air Conditioner
CONDENSATE WATER LEAKS FROM INSIDE UNIT
Check to make sure that the drain hose is properly installed and free of clogs. If that isn't the problem then check to make sure that your filter is clean and properly installed.
Jul 26, 2011 | Samsung AS18A6RB Air Conditioner
Why isn't there drain holes in bottom of window air conditioner? I drilled a hole for water to drain. Is there a problem with this?
It shouldn't be a problem if you drilled the hole near the rear, outer edge of the drip pan and didn't accidentally pierce any of the mechanical above it. Also, be sure the rear of the unit is tilted down at least 1/4" to 1/2", so water will flow to it. Check the drain hole periodically, as they will become clogged over time.
Thanks for choosing FixYa.
Jul 23, 2011 | Haier hwr10xc6 Air Conditioner
2004 Audi a4 1.8t air conditioner isn't working
Hi,the draining pipe is on that side it can be that its blocked just lift carpet and have a look where water is coming from
Jul 20, 2011 | 2004 Audi A4
I have an LG LWHD2500ER wall air conditioner about 2-4 year old. The digital read out comes on but the unit will not come on.
The unit isn't kicking out any water. And its not cooling like it normally does. How can I fix this issue?
Oct 15, 2010 | LG LWHD2500ER Wall/Window Air Conditioner
Water seeps into the rear passenger floor board during and after rain 2006 towncar
check the exit of the air conditioner. maybe is blocked. and instead of taking the sweet out of the car, is dripping inside. that is easy to do, and the exit of the air conditioner is usually visible on the engine side of the panel.
Apr 27, 2010 | 2006 Lincoln Town Car
My dometic RV rooftop air conditioner is leaking on the inside of the camper even after I cleaned the water condensation drain on top of the roof. What could be causing this? The fan is blowing the water...
Remove all covers and look down with them removed and see if the coil drain pan has a stopped up exit where the water drains out and into the rear of the AC unit.
If the unit is off level it could cause a draining problem too.
Jul 10, 2009 | Dometic Rooftop RV Air Conditioner
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Friedrich QuietMaster Deluxe RS12L10 Air Conditioner Logo
59 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
