Question about Smeg FA350X Stainless Steel Bottom Freezer Refrigerator
Smeg UKFC 40RX
The Fridge appears to be staying at room temparature, although the Freezer is OK. The green light is ON
The Fridge thermostat was at 4 and I have tried it at both 9 and 0 for different periods. The condensor backplate does not feel cold nor have any condensation on it
I can hear and "feel" the compressor running
Does the unit have a separate compressor for each section?
  • evanron Sep 10, 2008
    I have the same problem with my fridge. The freezer is fine but the fridge is not cold enough
  • 183 Answers
SOURCE: freezer not working
The compressor does run warm but not hot, if the freezer is not cooling then the comp is faulty, approach local repair agent for cost. Regards The Advisor Smeg Agent
Posted on Aug 21, 2007
SOURCE: Fridge not cold enough and build up of ice at back of fridge
We had the same problem and were told that gas was not circulating properly. We had it topped up, but it broke a week later. It had to be scrapped.
Posted on Mar 30, 2008
SOURCE: SMEG FAB28
Check the seal is tight all around the door - clean it to within an inch of it's life.
Then make sure the drain hole (inside at the bottom of the fridge) isn't blocked (a long handled screwdriver with kitchen roll wrapped around it will suffice). You can tell the drain hole is blocked as it's characterised by the door being difficult to open in quick succession (plus - you can see it's blocked).
Next, defrost the fridge completely: Power off, open door on freezer compartment & fridge and mop up the damp. When totally dry, turn back on (without food - let it cool properly before putting food back).
I had the condensation problem and it's now sorted. Not sure which cause was responsible, but the 'solution' is worth a try.
David W.
Posted on May 22, 2008
  • 87 Answers
SOURCE: Smeg Fridge light
What you need to locate is the door switch mechanism for the fridge. These are normally located towards the top of the door and protrude so that when the door closes the switch is pushed in. To find out if you have a problem with the switch just press it when the door is open and the light should go off. The switch itself can appear in various forms either as a protruding rod or a curved plate which pushes upwards against the door side when it closes. If I could draw in this section it could be better explained. But if you look around the inside of the fridge on the side away from the door hinge then you should find something you can push. Sorry to be this vague. If you do need a replacement switch they are normally quite simple to change depending on where they are located, most are two screws, or just a push in type. Hope this has been of some help.
Posted on Jul 13, 2008
nuygas
  • 57 Answers
SOURCE: smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
Posted on Jul 11, 2009
Temperature light at back of fridge randomly goes from red/green and the temperature in the fridge does not appear to be stable?
on a fisher paykel I would call them direct, their help desk can walk you through some checks to see what the error is... if I needed service on this unit I would use who they suggest.. because if the servicer does not have access to the factory on FP HE IS GOING TO BE GUESSING WITH YOUR POCKETBOOK in hand... we work on FP everyday and we call often....... I hope this helps.... ken
Sep 29, 2014 | Fisher and Paykel Refrigerators
Smeg FAB28QRI thermostat not restarting fridge unless I hit side of fridge! Do I need a new thermostat?
It could be a loose wire on the terminal of the compressor. Also check for loose wires on the thermostat. If that is ok, the thermostat could be bad because it is a temperature controlled switch that turns the compressor on or off.
Jun 14, 2014 | Smeg FAB28QR1 Retro Fridge with Freezer...
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
Fridge/Freezer
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
May 12, 2010 | Refrigerators
Fridge side won't regulate temp. however the freezer will freeze to -9 and stay right there! How do you test the thermostat? or is this a common problem. The fridge was built in 01' and nothing has been...
the thermostat is either off or on, and it controls the fridge temperature the freezer is just a by product of the remaining gas from the fridge usually -20/30 degrees lower than the fridge, two problems would cause this leaked gas would reduce the cooling capacity of the freezer but the fridge should stay ok although the compressor would be constantly on trying to keep temperature. the thermostat can fail after time not being able to keep a regular temp and not switching the compressor on enough to cool the system. unless you have a frost free where is usually a relay that controls the compressor witch have a life time rating of so many operations.
Jul 23, 2009 | Electrolux Refrigerators
Candy Frostfree Fridge freezer, model CPCA240FFK
1st of all conferm that the compressor is automatically (through Thermostate) going to ON/OFF or not, if it automatically goes OFF, i sugges its OK. and if not its no problum. (Minimum 4 hours rest is Must of a compressor, u can maunally OFF it for daily 4 hours Sleep)
Take Care
Shafky
Jun 17, 2009 | Candy CPCA240FFK Bottom Freezer...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Smeg FA350X Stainless Steel Bottom Freezer Refrigerator Logo
124 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
