Pgm image processing
Hello
i am trying to do project in PGM format.i want to do preprocessing steps like resizing,rotation,edge detection etc. before that i need the info abt how to load image from file and displaying after proceessing.
can someone help me
i could nt get any info from internet
    Sergeant:
    Champion:
  • 326 Answers
Try Pinnacle Studio Plus software.
Posted on Feb 14, 2008
Honda h22 5 speed
stalls. ( ever tune it up,at the 60k service points? )
what year, no year , no joy, 1978 to 2001 , lots huh?
and what engine option, displacement (size)
over 10 engines
Third-generation Honda Prelude engines:
B20A/B20A1 - 2.0L DOHC PGM-FI 143/160 hp (Japan/Europe)
B20A3 - 2.0L SOHC 12v carb 104 hp North America
B20A4 - 2.0L SOHC 12v carb Global, except North America
B20A5 - 2.0L DOHC PGM-FI 135 hp (101 kW) North America
B20A6 - 2.0L DOHC PGM-FI 142 hp (106 kW) Oceania
B20A7 - 2.0L DOHC PGM-FI 150 hp (110 kW) Europe
B20A8 - 2.0L DOHC PGM-FI 133 hp (99 kW) Europe
B20A9 - 2.0L DOHC PGM-FI 140 hp (100 kW) Europe
B21A - 2.1L DOHC PGM-FI 145 hp (108 kW) Japan (SI States)
B21A1 - 2.1L DOHC PGM-FI 140 hp (100 kW) North America
Jan 11, 2014 | Honda Prelude Cars & Trucks
I have a 1996 Acura 3.5 R.L. just put a new fuel pump in and it won't start. It turns over, but will not stay started.
Check your main fuel relay.
Fuel Supply System
PGM-FI Main Relay
Description
This PGM-FI main relay is located behind the dashboard
lower cover. The PGM-FI main relay actually contains
two individual relays. One relay is energized whenever
the ignition is on. It supplies battery voltage to the PCM,
power to the fuel injectors, and power for the second
relay. The second relay is energized for 2 seconds when
the ignition is switched on, and when the engine is running.
It supplies power to the fuel pump.
PGM-FI
MAIN RELAY
FUEL
PUMP
RELAY
Relay Testing
NOTE: If the engine starts and continues to run, the PGMFI
main relay is OK.
1. Remove the PGM-FI main relay.
2. Attach the battery positive terminal to the No. 3*
terminal and the battery negative terminal to the
No. 2* terminal of the PGM-FI main relay. Then
check for continuity between the No. 5* terminal and
No. 2 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 3.
• If there is no continuity, replace the relay and
retest.
*: 8P CONNECTOR
To FUEL PUMP
3. Attach the battery positive terminal to the No. 4 terminal
and the battery negative terminal to the No.
7* terminal of the PGM-FI main relay. Then check
that there is continuity between the No. 3 terminal
and No. 1 terminal of the PGM-FI main relay.
• If there is continuity, go on to step 4.
retest.
4. Attach the battery positive terminal to the No. 1 terminal
and battery negative terminal to the No. 2*
terminal of the PGM-FI main relay. Then check that
there is continuity between the No. 5* terminal and
• If there is continuity, the relay is OK;
If the fuel pump still does not work, go to Harness
Testing on the next page.
retest.
To PCM CONNECTOR
TERMINAL A4
To ST. SWITCH
To GROUND
To IGN. 1 To BAT
To PCM
CONNECTOR TERMINALS
A13 and B1
FUEL PUMP
RESISTOR
FUEL PUMP
Sep 18, 2013 | 1996 Acura TL Series
Show me a picture where the fuel pump relay is located on 1994 Acura Legend?
Acura Coupes and Sedans 1994-2000 Repair Information
PGM-FI Main Relay
Print
This relay is located behind the dashboard's lower cover. It consists of two individual relays. One is energized whenever the ignition is ON , thus supplying battery voltage to the Powertrain Control Module (PCM). This relay also supplies voltage to the fuel injectors, and power to the second relay. The second relay is energized for two seconds, when the engine is turned ON , to power the fuel pump.
See Figure 1
Fig. Fig. 1: Schematic of the PGM-FI relay
Testing
If the engine starts and continues to run, the PGM-FI relay is working and does not need to be replaced.
See Figure 2
Fig. Fig. 2: PGM-FI relay terminal numbers
  1. Remove the relay.
  2. Apply battery voltage to the number three terminal.
  3. Ground the number two terminal.
  4. Check for continuity between terminals five and two.
  5. If continuity is detected, proceed to the step 7.
  6. If there is no continuity, replace the relay.
  7. Connect the number four terminal to the positive side of the battery.
  8. Ground the number two terminal of the relay.
  9. Check for continuity between the number five terminal and the number two terminal of the relay.
  10. If there is continuity, the relay checks out "OK". If the fuel pump still does not work, test the harness.
  11. If there is no continuity, replace the relay and retest.
Mar 11, 2013 | Cars & Trucks
Can't load more pics to internal memory,past about 100 photos
Your jpg files(pics) may be too large.
reduce them (i use 800x600.)
Irfanview is a good resize pgm(free)
fred
Dec 11, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Buzzing fuel pump
sounds like the fuel pump relay is stuck on. find the relay and replace it. hope this helps mike
Jun 16, 2009 | Acura TL Cars & Trucks
How can i run thm files on my laptop
Rating: Not rateds2.pngs2.pngs2.pngs2.pngs2.png
Released: Nov 14, 2008
Platforms:
windows.gif Contenta-Converter is a simple and powerful tool to convert, resize, rename, organize and email your photos. Handles jpg, jpeg2000, gif, png, tiff, bmp, wbmp, targa, ppm, pgm, pbm, xpm, ico, cut, g3, dds, iff, jng, koa, mng, pcd, pcx, ras, sgi, svg, ps, eps, pdf, psd, raw, dng, crw, cr2, orf, mrw, thm, nef, pef, srf, arw, 3fr, erf, kdc, sr2, raf, x3f, dcr, drf, mef, mos, ptx download.gif Download:
www.contenta-converter.com
Nov 29, 2008 | Computers & Internet
Face recognition in java
http://www.ifp.uiuc.edu/~krejcark/Demo/DemoParams.dat
Mar 21, 2008 | Computers & Internet
Java programming
There are 2000 jpeg libraries in Java out there, easily searchable on search engines, sourceforge, maybe versiontracker, and secondly, you're asking for (what should be application-specific -output-; why would you hobble input) crop/resize without hinting at your algorithm? First, get a real programmer....
Java project for college applications? Gee, how about one to take a personality inventory (the INTJ type; only padded out) including areas of interest and make people little public/private spot codes (2D barcodes, like the ones in Japanese magazines) to indicate their type. The camera in a cellphone with J2ME can read the codes, maybe.... The cool part is that they're coupled with either P3P in wikis or java applets that help communicate with that person if you're an type that would otherwise take bothersome human care and preface to communicate.
There are all kinds of little systems you can build to thwart the draggy bits of Alzheimers' etc. with various little expert systems, that come up when you read a science journal (Nature, Science, Dr. Dobb's Journal, JAMA, JVNA....
You could invent something other than big-headed anime characters to add a personal visual reference to GUIs; emobots were cool, but maybe you can have a **** Cheney's Hands IM environment if it doesn't already exist (see also: Galludet University (for deaf students) stuff.)
Mar 20, 2008 | Computers & Internet
Raidoshack 1000 channel scanner
The frequencies probably aren't the same, so you're gonna have to do a little research, but hope this helps.
  1. Turn the scanner off and then back on.
  2. The first thing we'll do is clear all of the frequencies in the bank you'll use to listen to Gwinnett County.
  3. Press the black F button, then press 0, then press the F button again, then press CL, and then press the 1 button.
  4. Enter 000 and then press PGM to enter programming mode starting at channel 0. On the display the P on the left of the first line of the display says you're in programming mode, and the 000 indicates your looking at channel 0.
  5. Press the orange T button to enter trunking mode.
  6. Press the MODE button until Motorola is displayed on line 2 of the display.
  7. Press the PGM button again to begin entering frequencies. You'll enter 24 frequencies total. If you make a mistake while entering a frequency you can press the CL button to delete the last number entered. If you accidently press the PGM button twice while entering frequencies you can press the down arrow to back-up to the previous location.
  8. Enter the first frequency, 854.78750, then press ENT and then press PGM to go to the next channel.
  9. Repeat step #8 for the rest of the frequencies 854.81250, 854.83750, 855.31250, 855.48750, 855.76250, 855.78750, 855.81250, 856.81250, 856.83750, 856.91250, 857.81250, 857.83750, 857.91250, 858.78750, 858.81250, 866.13750, 866.21250, 866.38750, 867.33750, 867.38750, 867.96250, 868.11250, 868.13750, 868.48750.
  10. To double-check that you entered all of the frequencies correctly enter 0 and then the PGM button to go back to the first frequency entered.
  11. Press PGM to go through all 24 frequencies, if you see a mistake enter the correct frequency and then press ENT to save it, continue pressing PGM until you have verified all 24 frequencies.
  12. Next press 0 and then PGM to go back to the first frequency again.
  13. Press the MODE button until you see MO following the channel number on the first line of the display (P000 for example). After MO is displayed press PGM to go to the next frequency.
  14. Repeat step #13 for each of the 24 frequencies.
Mar 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Clock adjustment
Turn system off. On remote press the MEM/PGM button. The hour will blink. Use the tuning buttons on either the remote or system to advance or reverse the hour. Press the MEM/PGM button again to make minutes start to blink. Again, use tuning buttons to advance or reverse as needed. Press PGM/MEM button one last time to finish the process.
Really, could this be any less intuitive?
Hope this helps people out. :-)
Sep 01, 2007 | Sharper Image SA260 CD Shelf System
Computers & Internet Logo
51 people viewed this question
Alun Cox
David Payne
David Payne
