Question about Sony Ericsson W200i Cellular Phone
Phone is completely dead- will not switch on - battery was not flat as recently charged. tried to charge it again but no response
  • dolcevita23 Feb 20, 2008
    My Sanyo VI 2300 won't start up. The battery used to show as completly charged, but would die quickly. My mother said it runs down so fast because I need to shut off the phone and charge it fully once a week. When I tried that, it would not turn on. It finally turned on, the screen said "service required. Call for assistance." I called and the series of numbers to enter did nothing. Eventually, I let he battery run down until the phone turned off, I charged it again, and it began working.
    But this time, that didn't work. The nearest service center is an hour drive. Any suggestions? I tried taking the battery out, holding down the on button whilet he battery was out, replacing the battery, and turning it on. Same "serivce required" display.
  • Anonymous Jun 14, 2008
    nokia 1100 working perfect,next time I picked it up was dead ?
  • 983 Answers
May be there is some problem with battery try putting any of ur frnd s handset compatible battery in to it and just have cross check ...
may be the battery is dead due some indeed things like overcharging or bcoz of heating effect....
may be power on button inside is gone...
or the charging ic is gone....
if problem persists then contact the technician ...
this simple problem he will not charge more than 300 ..
Posted on Feb 07, 2008
How can I retrieve contact numbers from my fone that has discharged and wont charge
My phone died and now won't power on or charge. Here's how to fix it. Did your mobile phones battery drain all the way to zero and now your device is completely dead, not powering on or not even letting you charge it? This article will go through some tips on how you might be able to revive your dead phone.
If your cell phone is a smartphone then this is a reasonably common issue. It used to be a general practice to run older batteries to zero battery life before charging them back up to full again but try not to do that on the new smart phones, they use lithium-ion batteries which discharging 100% is a major concern and isn't good for the health of the battery.
If your battery has drained to zero and now the phone won't respond then try this
Pull the battery Start out by pulling the battery out of the phone for a few minutes then put the battery back into the phone, put the phone all back together and then plug it into your ORIGINAL charger that came with the phone. Make sure that you use the original charger that came with the phone. If you don't have the original charger then make sure that your charger is a manufacturer approved charger. If your battery is built into the phone and you cannot remove the battery from your smartphone then try to perform a simulated battery pull. Many phones have a method to restart the device, usually by holding down specific buttons or keys on the device. Much like the Motorola Atrix HD simulated battery pull or the Sony Experia simulated battery pull where you hold the volume down key and power key simultaneously while the phone is powered off.
Check the outlet Sometimes we can be too close to an issue and can overlook something as simple as a wall outlet attached to a light switch that's turned off. If the light switch is designed for turning off and on a light and the switch is off then there is no power coming from the outlet and obviously your device isn't going to charge.
Try a different outlet This can go hand in hand with the above suggestion. Try a different outlet to make sure it's not a power socket issue.
Try using a computer or car charger Using a computer or car charger instead of a wall charger can sometimes put a quick charge on your battery and get it to respond as well. Keep charging it If you have tried these methods and your phone isn't responsive due to its battery being drained 100% then it can be difficult to get your phone to charge again. Try charging it for at LEAST a couple hours on an outlet you know to be working, even all night if possible. Lithium ion batteries can take a while to get to charge again if drained all the way. So try charging it for a while, You might need a new battery If you try these tips and suggestions or have tried all these things already and there is still no response, and your phone is completely dead and will not recognize a charger then you might need to try another battery.
Try a different charger If you have tried a different battery then make sure you try your original charger first, as mentioned above. If there is no response then it might not be your battery but your charger that has malfunctioned and might need replacing. If you have any spare chargers try those to see if you can get a charge out of your phone. Replace the device If you have tried a different battery and a different charger and your phone is still little more than a paper weight then you should start reviewing your phone replacement
Sep 30, 2016 | Cell Phones
Running fine, all of a sudden car is completely dead
sounds like short somewhere draining battery. Might be alternator causing this also. can have it checked at autozone at no cost....good luck and hope this info helps....Please rate this post.
Aug 15, 2012 | 1995 Nissan Maxima
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
After fitting new battery on my fjr 1300 Drove a long journey stoped and it would not start as if the battery was dead. left it for a while and it started with loads of power in the battery any thoughts...
Have your charging system looked at, first do a simple multimeter test, get a multimeter, switch it on to Volts, start bike and see what it reads, put multimeter prongs directly on battery, very simple, if its below 12V you have a charging problem. If your battery is new and your charging system is faulty the bike will start and go, but when you switch it off the battery will be dead because it has not been charging. When you let a dead battery sit for a while it will charge itself a little, enough to start the bike up. Have you ever had a flat torch or mobile phone, it will die when battery is flat but when you try and switch them on again after a little while, they will work a little and die again, same with bikes, cars etc. All the best, Forever Two Wheels :)
Mar 28, 2011 | 2002 Yamaha FJR 1300
Phone is completely dead. Battery is fully charged and I have taken the battery out and put it back in but still phone is dead.
Hi, how would you know battery is fully charged, and phone is still dead?.
You will need to confirm by using another battery to know if it is not a battery problem before you proceed to the next option.
After checking,if no response yet, that means you will now know that the phone is experiencing power problem.
To solve power problem,you will need to service the phone and flash the phone.
You can use this link to flash the phone for it to power up again.
(unlocktotalk.com/UnlockCodeInstructions.htm)).
And for the servicing of the phone, contact a technician.
Note: service before flashing.
Take care.
Jun 16, 2010 | Nokia 5230 Cell Phone
My phone is not holding a charge. It seems completely dead, and when I try and charge it it flashes sporodically and vibrates for a second or two before dying again
When your phone tries to come on and goes back off after vibrating for a second or two.
This is due to the fact that the battery is completely dead and is trying to pick up when you plugged it to the charger.
Try to charge the battery of your phone in another phone before fixing it back into your phone.
turn it on before trying to charge it again.
make sure the battery never runs out before you charge it back.
take care
Jun 12, 2010 | Sony Ericsson K850i Mobile Phone
Phillips CD445 cordless phone - cuts out when pick up to answer
if you have had it a while chances r the batterys have had it even though they show full, try a new set, or even try standard batterys briefly while fone is not in charging mode to see if they work during a call.
Jul 30, 2017 | Philips CD4450 1-Line Cordless Expansion...
My battery went dead this morning i charged it this evening and it is just showing a battery and timer wont switch on or charge??
from what I hear, you have either fully charged your battery or your battery is pretty much completely dead.
your options:
1. If it's completely dead and won't hold a charge it's time to purchase another battery, this happens from time to time so don't freak out about it.
2. If it's fully charged, try taking the battery completely out of the phone, and re-inserting it after a few minutes, sometimes cell phones need to be reset.
3. ensure that your charger is working properly, if its not getting juice to it neither is your phone.
4. try to dial your number just to see what happens to the phone.
5. if someone else u know has a charger like yours try to borrow theirs to charge your phone possibly ruling out a bad charger
Nov 13, 2008 | Samsung Cell Phones
Sony Ericsson W200i Cellular Phone Logo
91 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
