Half a screen
Had water sprayed on it .turned on and only half the screen works now
  • 3 more comments
  • neil marriott Feb 07, 2008
    it is a lcd panasonic tx-32lx500a all works but half of screen is black
  • neil marriott Feb 08, 2008
    hello. thanks for info.i will try over weekend and let you know.
  • neil marriott Feb 09, 2008
    HELLO harry0000010. have tried your check .could not see anything.what it is doing is good picture then 2/3 across screen is a thick black line about 8 inches then thin white line .then black about 1.1/2 inches then thin white (1/4inch)another black ( 1.1/2 inches) then thin white.picture is okay then
  • neil marriott Feb 19, 2008
    can any body tell me were i can get a used good lcd screen in australia for a panasonic tx32lx500a .my screen is okay but the water problem has eaten out the tracks on the boards at the base .cannot repair these .the screen is acually a sharp..
  • Michael Harrier May 11, 2010
    if this is a plasma...then you will need a Ysus both upper and lower registration boards...can you give me the make and model...and I'll see if i can get you the part numbers..and where to order them.
    Problem Solver:
  • 40 Answers
OK...ON THE SIDE THAT IS OUT(HAS NO PIC)...SHINE A FLASHLIGHT ON THE PANEL(WHILE THE TV IS ON)..AND SEE IF THERE IS A VERY FAINT PICTURE...IN SO..YOU WILL NEED THE INVERTER BD
Posted on Feb 07, 2008
  • Michael Sparrow
    Michael Sparrow Feb 11, 2008
    It sounds like a bad panel...but if water got down inside the tv...and
    onto the electronics!!!.....you might have blown the Scalar bd...which
    converts digital info to the panel. Very unfortunate...exactly how did
    it happen???....and how much water got inside?....i went to the
    panasonic website and researched replacement parts...they do not list
    any component parts...only a parts change bulletin for the stand....you
    will have to call them(1-800-572-2672)..and see if there are parts
    available..and possibly where there is a service center near you...i
    hope you have some warrantee on this unit...it would save you some cash
    on the parts/labor
How do I remove the main oven inner glass to replace the seal? The screws which appear to hold it in place only do a half turn!
THE SCREWS MAY BE WORN AND STUCK OR THE INNER GLASS HAS BECOME SO GREASY THAT YOU MAY NEED TO USE SOME THING TO GET RID OF THE GREASE AND GUNK TO SLIDE OUT THE DOOR. MIX IN SPRAY BOTTLE WITH ABOUT 3/4 VINEGAR AND THE REST OF THE BOTTLE WITH WATER AND SPRAY INTO THE SCREW HOLES OR IN BETWEEN THE GLASS SEE IF THAT WILL WORK FOR YOU.
Jan 27, 2015 | Ovens
After trying to use sprayer in kitchen sink, now facuet will not work
The Faucet may be clogged with dirt, or screen is clogged.
Nov 15, 2013 | Plumbing
I have a Vigo Faucet with a commercial spray arm. When I depress the spray lever it sprays for a second then stops and then when I try to use the regular faucet nothing comes out. Then if I turn on the...
Clogged sprayer.
take apart the screen on the sprayer and clean it out. run the water through the faucet without the screen for a minute and then reassemble.
Sep 13, 2013 | Plumbing
Hello, Dishwasher is not cleaning well, it leaves a white film coating especially on top rack items. thanks
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins.
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Feb 13, 2011 | Dishwashers
After a regular dishwashing cycle, our dishes and glasses are not getting clean. They are left with a white film. We have checked and all holes in the spray arms are open. We have tried a rinse agent,...
Hi
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
Hope this helps... Please post back if you need more assistance.
Feb 09, 2011 | KitchenAid KUDR24SE Built-in Dishwasher
Glasses on top rack are dirty on outside of glass, looks like soap scum
Hi
Daniel
Feb 09, 2011 | Frigidaire PLD4375RFC Dishwasher
My top rack is not getting clean, it appears spray arm is not dispersing water, can it get clogged?
Yes it can get plugged. Any debris pumped up to the arm can get lodged into the tiny holes. Also, sometimes the arm itself becomes split along the joint between the lower and upper half. Remove the arm to inspect, clean, and repair/replace the arm if split. I fixed our Maytag spray arm when it split, by drilling a series of small holes along the split parts and sewing the thing back together with fairly fine copper wire. Still working great after a number of years. The small spray holes can be poked clean with a heavy needle and the arm vacuumed out. If after all this it still won't spray properly, the intake screen at the bottom of the lower spray arm tower may need to be cleaned as well. Remove components starting with the spray arm and work your way down, noting placement and orientation of each piece. Remove the screen, and soak it in hot water, detergent and white vinegar for an hour or so. Check all holes in the deck for any food plugging. Reassemble in reverse order and check the lower spray arm for plugging as well. Hope some of this helps!
Jan 08, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My moen vestage faucet is dropping water pressure. It worked fine when it was installed but the water volume out of the faucet has dropped to less than half of what it was.
Have you removed aerator ,screen etc., from end of tap, to see how flow is with it off. If good, or same as other taps when taken off of them, then you've got debris in aerator, and screen.
Jan 03, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Televison & Video Logo
288 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
