Question about Artec T2 Happy Go Portable DVD Player
Spares for Artec Happy go
The battery does not get charge. How can I determine if the problem is the baterry or its charger?
The remote control is not working. How can I get a new one?. Is there any universal remote control compatible?
I need a new battery and a new ariul
Posted on Sep 25, 2008
    Master:
    Sergeant:
  • 462 Answers
Dear UIOEC
You can use a digital multimeter to check both if the charger and battery are working, but u should know how to use a multimeter, it is simple. And for sure u can get a universal remote control.
Posted on Feb 07, 2008
How to charge baterry of zen wireless mouse ?
You should get a battery charger separately for charging the batteries. Specify the seize of the battery and get a suitable battery charger from local electric store.
Oct 27, 2012 | Samsung Zen Keyboard and Mouse
Blowing the fuse when trying to charge
I would think that a circuit is bad in the charger. Have you tried another battery?
Jan 29, 2012 | Ryobi Drills
Drill not working, not sure if baterry is shot or charger is bad .Baterry on charger for couple hours and no charge, red light on charger not lit
If he light on the charger is off, then your problem is almost certainly the charger. If you can get a working battery from a friend or someone, try that and if the light stays off you've confirmed the charger is bad.
Apr 21, 2011 | Milwaukee Drills
I changing my car battery I put disstilled water ang I charge after 5 hours my baterry was same voltages when firts I cheked how know to if my baterry need to replace and how to know if my baterry are not...
voltage is 12 V or so, is an ok thing to measure.
But, it must be measured under load to determine if there are enough CCA or cold cranking amps to perform well in your vehicle's starting system.
Jun 24, 2010 | Car Audio & Video
I am not getting any power to the laptop i have the battery disengage from the laptop with direct power it is still not comming on
you need to put the baterry back on if the battery is bad replace it, the charger is for the baterry. a laptop needs a battery to work, the power that is coming out of the charger only charges the battery it isnt going to power on the pc, it is for maintaning the proper voltage in the battery.
Jun 03, 2010 | E-Machines M2105 Notebook
Why i charge the baterry(GP2700) whole night when i snap the picture only 2 picture can use.many times already not only gp rechargeable baterry but (panasonic 2700) also.can someone solve my problem
If you have a friend who uses the same battery try one of yours in their camera to see if it works properly. Alternatively, try the opposite and borrow a known good battery from a friend and try it in your camera.
You either have a major problem in your camera, a coincidence of two dead batteries or a broken charger. Make sure all you connections are clean. Just a simple piece of printer paper rubbed over the battery contacts is enough to clean them. Ensure the charger connections are clean and even the connections in the camera. Check the lights on your charger. Is there any indication the battery is flat to start with and any indication of when it's charged? Usually a red light means the battery is charging and that light going out or turning green means it's charged. The battery shouldn't have to be on all night. Usually it should take maybe an hour or 2.
Finally, how long have you had your batteries and are they Li Ion or NIMH. Nicads are no good for digital cameras. They can develop memory problems. So if they are Li-ion or Nimh ensure you are using the correct type charger for those batteries
Apr 14, 2010 | Kodak EasyShare C653 Digital Camera
My phone is fairly new ( a few months old) and for some reason the charger wont charge when I plug it in. I've tried unplugging it, putting it in different outlets, taking the battery in and out etc but...
i think your baterry is drained already..try to charge your battery in a universal charger, or a clip charger.then continue charging with your original chargermoz-screenshot.png7bf4754.jpeg
Apr 13, 2010 | Motorola Mobility W376 Cell Phone
Where can I find a replacement charger for the allegheny ciw114 impact wrench?
If the battery is not damaged or totally dead, you can attempt to charge it with any
24-Volt DC charger. The charging voltage rises to about 28 Volts when nothing is
connected to the charger. You must first connect (with jumper leads) the positive
charger output to the positive battery terminal. Use a test meter to determine the
polarity of the battery. Also test the charger output to determine the polarity. Be
sure to connect positive to positive and negative to negative. Do this before turning
on the power to the charger. If the battery is a "smart" battery; that is with built-in
electronic control circuit, the ordinary charger may not work. Normally, a battery
will accept a charge until it is nearly completely charged and then the battery
voltage will slowly "buck" the charging voltage. When the battery voltage and the
charging voltage are equal, no more charging current will flow. Amperes, that is
coulombs of current, charge the battery; when the battery is at (approximately) 24
volts and the charger is putting out 24 volts, NO current flows. The battery is then
fully charged.
Dec 28, 2009 | Impact Allegheny 1/2'' Drive 24v Cordless ...
Baterry Backup only rest for 10 minutes
its better take your laptop to the service centrel and complain about the battery status there, because your laptop is still under warranty, its better to avail the warranty
Nov 06, 2008 | HP Business Notebook 530
Batteries show charged but no pwr
Clamp one side of [power line of your charger insert baterry pack,if amphere increase the battery pack was ok.select battery good one still run impact diver insert to the charger amphere increase good charger and battery pack. Two only the problem Battery pack or charger, if charger not function , the power transistor will be replace or buy new charger.
Dec 25, 2007 | Makita 18V LXT Lithium - Ion Cordless...
Artec T2 Happy Go Portable DVD Player Logo
128 people viewed this question
Top Artec Televison & Video Experts
Marvin
Marvin
Are you an Artec Televison and Video Expert? Answer questions, earn points and help others
