Question about SanDisk Sansa E280 MP3 Player
Key Locked Ok, I tried to turn on my Sansa e280 8GB mp3 player the other day and it came up with the screen "Key Locked" and following that it said "System Shutdown". I posted another problem like this and somebody told me to put it into recovery mode, which i did. In recovery mode it says "Welcome to Recovery Mode" then "Please connect USB Cable". So i plug it in and it says "Enter USB2.0 MSD mode" and a folder named 16MB-FORMAT (E:) popped up. Inside it has a Text Document named VERSION. What do I do now to get my Sansa to stop saying Key Locked System Shutdown.
  • 8 more comments
  • respecter
    respecter Feb 08, 2008
    Ok, computerrep, your the man so far. I've downloaded the firmware onto my cpu from the URL you gave me. What do i do now after ive downloaded the firmware onto my cpu?
  • respecter
    OK, computerrep, when i plug my sansa into my cpu it says Key Locked, System Shutdown. Do I need to put my sansa into Recovery Mode then it will automatically download?
  • respecter
    Also, when i downloaded the content from the URL you gave a new icon called Sansa Updater was on my desktop. I clicked it, followed the procedures it gave me and i restarted my cpu and i clicked on it again, it installed it and then it was done. it will still automatically download when i plug my Sansa in? also did i do everything right?
  • respecter
    respecter Feb 09, 2008
    I downloaded it, plugged in my sansa and nothing happened. was i supposed to be in recovery mode because if i plug it in it automatically shutdown cause of key locked?
  • PalmerMi Apr 05, 2008
    Tried Recovery Mode and Updater. Still no luck. BTW, you get to Recovery Mode by pressing the left button 'Rec'.
  • Anonymous Apr 25, 2008
    i turn on my sansa e200 and it says load main image failed, switch to recovery mode, then it shuts down
  • Anonymous Jul 02, 2008
    key lock
  • trombie Aug 08, 2008
    it keeps saying key locked system shutdown.
  • raamg Dec 05, 2008
    key
  • alliegatorwa Mar 22, 2009
    I have the same problem. My sansa mp3 player will turn on, thenflash "keys LOCKED, system shutdown." I just wanted to know, how do you get into recovery mode?
    Problem Solver:
  • 9 Answers
Sounds to me like your hold switch is on. Have you tried sliding your hold switch on top of the player, next to the headphones jack to the off position?
Posted on Feb 08, 2008
IF THE KEYS ARE LOCKED THERES A BUTTON ON THE TOP THAT HAS A PADLOCK ON IT! SLIDE THE BUTTON OVER AND IT WILL WORK >> IT DOES THIS SO IF YOU HAVE IT IN YOUR POCKET AND YOU LOCK THE SONG WONT CHANGE!
Posted on Jun 05, 2008
  • 758 Answers
I would recommend you to reinstall the firmware on the device..it appears that the firmware is corrupted....The link to download the firmware is below
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
If you still any assistance you can contact me or you can call sandisk at 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
  • 1 more comment
  • Jean Sintulaire Feb 08, 2008
    You need to install the firmware and then plug your device..it will automatically aupdate the firmware..
    Aslo please check to see if the hold switch is not activate..The Sansa e280 Hold Switch is located on the side of the device, and is used to prevent any accidental
    operation. Once the Hold Switch is moved to the lock position, all function keys will be disabled.
    Buttons on the Sansa E280 will not operate when the Hold Switch is active.
    Now that you update the firmware it wont ask you to do it again it will notice that you have the msot recent firmware available and yes you did it right...
    Hope that helps..
    Thank You
    Computerrep
My MP3 player won't turn on. It says key locked
its cause it is on lock on the top of your player there will be a switch that says "hold" flip and try again
Mar 24, 2010 | SanDisk Sansa e250 MP3 Player
Mp3 player locked
there is a hold key in your player...jus put it on unhold position...
Aug 15, 2009 | SanDisk Sansa e270 MP3 Player
I turn my sansa 280 on, it displays "key locked, system shutdown
there is a hold button on the top of your device. move it to the left and then turn it on.
Mar 22, 2009 | SanDisk Sansa E280 MP3 Player
Key Lock Sansa e280
on the top is a switch that says lock /unlock ......... switch to unlock
Dec 18, 2008 | SanDisk Sansa E280 MP3 Player
''Key LOCKED. System Shutdown.'' Problem
Disengage the hold/lock button on top of the player.
Nov 23, 2008 | SanDisk Sansa e250 MP3 Player
SAnsa MP3
On the top of the player you should see a switch. Push the switch over until you can't see the orange side.
Oct 20, 2008 | SanDisk Sansa e200 MP3 Player
Key locked system shut down
On the top of the player there is a slider. When it is showing orange next to it your player is "Locked" so accidental button pushing wont mess up your tunes. Slide it over so it shows only white instead of orange and your player should be just fine.
Jun 18, 2008 | SanDisk Sansa e250 MP3 Player
Key locked system shutdown
Turn off the HOLD button on the top of the SANSA Thank you Computerrep
May 01, 2008 | SanDisk Sansa e200 MP3 Player
My sansa 250 e
try running your sansa out of battery so the screen shows [to low of battery] then plug in your sansa to your computer and resync your music
Feb 09, 2008 | SanDisk Sansa e200 MP3 Player
Sansa E 260
You have locked the keys, look for a switch with a red , white or orange lock icon and move it then try to turn it on. The switch should be on the side of the player, either at the top, bottom or sides of the screen.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
797 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
