Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Check paper tray - reload paper
Even though the tray is full of paper - we keep getting a message to check the paper tray and reload paper.
    Scholar:
  • 95 Answers
Your paper sensor actuator arm is most likely broken or out of position, or you may have a dirty sensor if you are in a dusty environment. If you look in the machine with the tray out, you should see a small (usually black) piece of plastic hanging down. You can also take the toner and drum cartridge out and turn it on its back to get a better look. If it's not there, it's probably broken off.
Posted on Feb 08, 2008
I reloaded the paper tray. Now it says "no paper pick-up, even though I have 2 trays I can get neither to work. I have tried nv ram. The printer is only 3 months old and I can see nothing wrong with...
Check under the paper tray, paper lift has to be act with the help of "knoch"( a small plastic part along with the spring to lock the paper lift) while loading the tray. If its broken or nor functioning properly paper wont lift to pickup, result error shows reload the paper tay, if "knoch" is good chek under the tray there is a metal frame drives the "knoch" If its not connecting properly make the frame slight bend to ward to up side at the centre pont. load the tray and observe whether paper lift acting or not. .
Best of luck..
Vinay.Hyderabad.
vinay229229@yahoo.co.in.
Apr 18, 2011 | HP Laserjet M2727nf Multifunction Printer
Photosmart C309a series Printer (brand new) will not print
check the Tray. there are markings on the tray that tell the printer what paper is loaded, if the tray isn't in the percise location of type of paper, you'll get that error message. If that isn't it, then check the sides of the tray and see if there is any damage. sometimes the tabs on the trays that tell the printer what paper is in it, get broken. If that isn't it, then look inside the printer where the Tray goes in, and look for damage, or bent metal feelers that rub against the tray,
Oct 01, 2009 | HP Photosmart Premium C309A All-In-One...
Brother HC4040CN displays error message NO PAPER even though paper tray is full. Will not feed paper from Main tray.
The paper sensor flag above the paper tray on the printer chassis is either stuck or has broken of. You need to take the printer for repairs.
Aug 04, 2009 | Office Equipment & Supplies
Panasonic Workio 1810 - Tray 1 Add Paper Message
First why is the tray set for size A4 Paper. That is metric size paper for oversea locations. Should be set for 81/2"x11, or 11"x81/2.. is there any paper stuck behind the 1st tray? are the guides that hold the paper in place in the draw snug up aganist the paper in the draw. is the bottom sheet of paper in the stack/rem of paper benton the edge. All sheets of paper in the draw must be flat.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 20, 2009 | Panasonic Office Equipment & Supplies
HP Photosmart C7280. Keeps asking to put paper in tray even though it is full. Lot's of noise coming out but no paper being pulled through.
When you get that message, ususally the rollers that pick up the paper have stuff on them that's made them slick. This video shows how to clean the rollers (and some other steps as well).
May 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
ImageRunner 2020 paper tray open warning - cannot fix
Are you check the sensor flaper for paper presence?
It is located above paper in pick up assy.Whe you remove the drawer you should be able to see the black flaper hanging from above.
Apr 08, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
Says add paper to large tray even though it is full
Depending on which large capacity feeder you have.
If you have the one that is on the bottom of the machine, make sure there is a gap between the paper in the front and rear of the paper tray, There is a black plastic guide in the middle of the tray that may be being caught by the paper.
If you have the large capacity feeder on the right side of the machine then most likely the black actuator that tells the machine the tray is full has broken or the sensor is bad,
Feb 12, 2009 | Toshiba E-STUDIO 650 Copier
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
426 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
