Question about Lexmark X215 MFP All-In-One Laser Printer
Lexmark x215 printer/fax/scanner
I have this machine on a telstra duo phone line.When I receive a normal call the house phone when answered squalks and screeches until I unplug the fax cable to the machine.Telstra has tested the line and says its ok.When I receive a fax call the machine works fine.Telstra says I have to program the fax setting on the machine but there seems no facility to do this.Any ideas would be greatly appreciated.Thankyou.My email is whiston@tisgroup.com.au
  • Anonymous Aug 28, 2008
    I have two #'s on same line, one for fax & one for phone. When I changed my toner cartridge, the rings somehow got mixed up so when people call me they get the screechy sound. I called BELL Telephone and they explained that the line was ok but my fax machine needs to be reset to react to the double ring. I am not technologicaly inclined so I'm hoping for guidance.
  • steveb215 Feb 10, 2009
    I have the same problem, wonder how to get the faxs out of mem.
I have an X215 also. It is not built to suit a duo line hence no fix is available.
Posted on May 23, 2008
Lexmark pinnacle pro901 will not receive faxes i can send but can not receive what do I do
Are you sharing your home phone line with your fax? Do you have an answering machine or a voicemail feature in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may want to subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Nov 02, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I cannot receive faxes on my lexmark X4270. It will ring but nothing come through
Please go through the following checklists:
  • Make sure the that the fax line is working. To check, insert a telephone device straight to the fax line. You should get a dial tone.
  • Make sure the telephone cord from the phone jack in the wall is plugged into the Line port on the back of your Lexmark printer.
  • Assign the correct fax number on the printer.
  • If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
  • If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
If these don't help, please contact Lexmark Technical Support Center for additional assistance.
Sep 24, 2011 | Lexmark X4270 All-In-One InkJet Printer
I cannot receive incoming fax, what setting do I have to use
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X4200 User's Guide.
  • Make sure the fax machine is connected to right phone jack in the wall and is assigned with the correct fax number.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 13, 2011 | Lexmark X4270 All-In-One InkJet Printer
We can't receive a fax!!! how are we supose to connect with a phne line and the computer???
You don't need to have a computer plugged in to the Lexmark printer to receive faxes. Here's an article on How to Configure the Lexmark X7170 to Receive Faxes. Just click on this link: http://bit.ly/d643uT. If you are sharing your home phone line with the fax and you have an answering machine on the same line, make sure to configure the answering machine to pick up first then the fax machine. Voicemail feature can also block incoming faxes. Once voicemail picks up the fax, signal won't be passed on to the printer. But if you want, you can also contact Lexmark technical support to further investigate the problem.
Aug 12, 2010 | Lexmark X7170 All-In-One InkJet Printer
Can't receive faxes
Hello. Make sure you're plugging the printer to the correct phone jack in the wall. If you're using a splitter, bypass it. Check the settings in the printer. Make sure you assigned the correct Fax number in it and place your Fax name as well. If you're sharing your home phone line with the fax and you have an answering machine, set it to answer first and the Lexmark fax later with a minimum of 2-ring gap. If you have a voicemail, turn it off since it will a conflict with the fax or avail a distinctive ring feature from your phone company so it can work with the fax. Hope this helps.
Mar 23, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x215 MFP All in one - prints fine but photocopy and faxes
you should clean the optics situed in the upper place of the machine, retirate the originals glass en clean all the mirrors are inside...
good luck...
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Lexmark X215 MFP All-In-One Laser Printer Logo
709 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
