Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Printer error 054
Our fax is making noise and does not print out the faxes.the messege PRINTER ERROR 054 comes up after each attempt at printing a fax.
  • anitashrini Feb 07, 2008
    thank you Mrvica,but we have checked for paper jam and have also changed the cartridge.there has been no change.
    any more suggestions would be welcome!!!
    as suggested,we checked and even changed the change,the fax still cannot receive faxes.
    please suggest any other solutions.
  • 167 Answers
That's because you need to take out cartridge and put it back! See is there any jamed paper inside!!! Error 054 is about cartridge!! Can't read that cartridge is inside the printer!!!
Posted on Feb 07, 2008
When Printing Of the internet script error comes up and printer will not prin
which web browser are you attempting to print from? and is this through a windows pc or is it on a different os?
Jul 30, 2013 | Samsung Clx-4195Fn 4-In-1 Colour...
Fax will not print: I connected the fax machine and plugged it in. It sends faxes OK. When a fax is sent to it, nothing comes out. The sending fax doesn't receive an error message, seems like all went...
Does the machine print anything? such as a directory or print when making a copy? I rather suspect it does not. When an incoming fax is recvd does the paper get pulled in and come out blank? If so your problem is with printing (or lack of it). Perform head cleaning. Also make sure the black cartridge still does not have its deal stuck on it. Post again if you still have problem.
May 05, 2011 | Brother Multi-Function Center MFC-3360c...
Display fax gives a warning "received in memory" we also have a warning "prepare black toner" We can not print the fax! What can we do?
Generally the "received in memory" message is a result of the machines inability to print. I.E. It received a fax, attempted to print it, failed, and then stored it in memory to print once the issue has been corrected.
The Prepare Black Toner error is likely directly related. If the toner cartridge is empty, inserted incorrectly, or damaged it could be causing this error. Try reseating the cartridge by removing and reinserting. If that doesn't clear the error try replacing it with a new Canon branded cartridge.
As soon as you correct the printing issue the stored faxes will print.
May 03, 2011 | Canon MF8180C Color Laser MFC Printer
Have an HP Laserjet M1319 Fax Machine. Fax line appears to be working but I can't send or receive faxes. It shows"receive" when they come in, but won't print them up.
Sometimes these machines will give you automatic messege "Recieve."
If this is only plugged in the fax machine, can you hear the machine dialing or hear the machine recieving a dial tone?.
Some machines have the audio sound turned off, so it is quiet when the machine is doing fax transmissions to limit the noise.
If you can turn it on you can make this eaisier to resolve. If it is on then you can make this more simplier.
Make sure the settings are set right, Junk mail turned off, set up the fax answer mode to print, and not store, check to see if the auto confirmation can be turned on. When this mode is turned on for this process at least you can get a print out on the fax copy, some will give an error messege.
If you can put an analog phone into the fax line, use another phone to call that number and see if it rings. This will ensure the phone line is working well.
If this line has a phone line converter, digital to analong, this may cause some of the issues. More and more people are trying to use the internet as their phone line as a fax.
I would like to know if any of this resolved the problem. There are more questions I have to this type of problem.
Good luck.
Oct 16, 2009 | HP Office Equipment & Supplies
Lost the Copy and Fax Receive Function
Hi Vic,
I'm sorry to say your fax machine has a bad LASER unit. A laser error code will stop all print functions. The laser units are no longer available.
Sep 15, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
I have a panafax uf755e showing error code 054 and it won't print the fax's
054 is a laser unit error. Switch off/ clear. Otherwise it's an engineer job and unlikely to be cost effective.
Apr 12, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Lexmark X160 doesnt Copy or print faxes
I have been getting a remote fax error often enough that's it's becoming a nuissance. Any suggestions on how to fix this problem?
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
476 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
