Here's a video on the same model/make with something that started as a noise. Turns out there are two different axles with the difference being the locking ring on the inboard end. Dodge Dakota Front Axle Noise
If you still think the noise is coming from the left side CV joint it would be more advisable to replace the entire axle as an assembly. For the time and effort it takes, you can usually get a rebuilt axle assembly for only a few dollars more than the CV joint and the boot required to repair one. You will need a large axle nut socket (usually 30 - 32mm) to remove the axle nut. The lower ball joint and tie rod will need to be separated along with the brake caliper and rotor, from the spindle. I would recheck the grinding noise before doing it. A lot of wheel bearings are mistakenly diagnosed to the wrong side. If the noise is loudest when turning left, most people would assume the left side wheel bearing is at fault. However if the noise is loudest turning left it indicates the right side wheel bearing is most likely at fault. Due to the weight distribution of the front end, turning left the weight all transfers to the right side, loading that bearing. Make sure thats not the case before tackling an axle.
I don't have a solution, but I thought it was really strange (coincidence?) that you reported this in June of 2010, and here it is September 2010 I just ran into the same problem. Same year truck (2001) and same tire (paasenger side rear). Only I heard a lot of noise coming from what I thought was a flat tire. So I had my brother drive the truck while I got in the bed of the truck and located the sorce of the noise. When he applied the brakes it looked as though the tire was going to come right off and I was like "Holy ****.....stop the truck!"
One lug was actually already broken but the tire was very loose on the hub. I then went to tighten the other lugs and 2 more snapped off (total of 3 broken) trying to tighten them. So the others sustained stress from all the movement which made them weaker. Right now I have 3 (maybe 4 can't remember now?) holding that tire on until I fix it.
Is this a defect in the 2001 Dodge Dakota? (I have a 2001 Dodge Dakota Quad cab with a 4.7 and about 95k miles). I was also hoping I woudn't have to take the who rear axle out. Once I get it up on the lift I'll be able to see it better.
I have a 2002 Dodge 1500 Ram 4x4, quad cab and had the same problem. In
2wd the clicking was constant, in 4wd it would go away. Also I had no
4wd while in 4wd, found that out after a snow storm. I took my truck to
a buddies garage (a Dodge mechanic), he said this is a common problem.
He pulled the drivers side wheel, hub, axle and stub axle. The stub
axle splines where it goes into the CV joint and and the internal
splines in the CV joint were gone. Almost smooth even. The wheel
bearing was completely wore out too. I ended up replacing the hub
assembly, both the inner and outer axles. Not a cheap fix either I
have about $600 repair bill, but it's back on the road now smooth and
quite.
Do you mean the front wheel hub bearing?
Thanks
