Question about Samsung RS2630SH Side by Side Refrigerator
Rs2360ww hot to the touch
The center rail between the fridge and the freezer where the door gaskets seat is extremely hot.
  • Buggered Feb 07, 2008
    We have the same problem. Waiting for repair that doesn't seem to be coming. We also have the grinding fan in the freezer. The entire thing freezes and we have to take the back off and defrost the unit every couple of months. This has been going on sense we got it (Nov 05). It would freeze so bad you could'nt even get a reading from the repair man. It had to be replaced. The "new" fridge is just the same, same problems that cannot be fixed and now we have the over heating/hot problem. All I could think of was to unplug it. I will try the other suggestions and if we can ever get someone to look at it we will let you know. No one seems to want to touch samsung... gee I wonder why. What a piece!
We had the same problem -- just bought a house that has a 2360WW model in it, and we kept noticing that if the doors were closed it would run and run, but if you opened the door it would stop running. come to find out the fan blades were actually hitting the shroud. ofcourse, whomever replaced this fan before installed with only one screw to the shroud, so the fan blades kept hitting the compartment that houses the fan motor, til it burned up. partstore.com has really good pricing. roughly $40 for new fan and blades.
Posted on May 11, 2010
Had to get a repairman. Turns out to be a bad sensor and fan motor. Too bad we didn't get the response earlier, would have saved $300.00. Maybe this will help someone else though!
Thanks for your input, you were right on.
Posted on Feb 16, 2008
    Sniper:
  • 65 Answers
Yellow pine ..when your compressor is running the condenser fan should also be running. located next to compressor. clean coils and replace condenser fan.
Interior wall of unit gets extremely hot
If you are talking about the wall that runs between the freezer and the fridge where the door gaskets actually touch. The answer is no. It should be warm though.
What can cause this is the fan that is located at the rear not operating or dirty coils under there. Check the fan it should be operating when the unit is in the cool cycle, if it is not then it will need to be replaced. And clean the coils. This will help.
May 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool gold side by side is extremely warm bordering on hot when you touch the upright section between the fridge and freezer, (where the doors meet)
As long as it doesnt affect cooling operation, this will be normal. There is a heater in that area meant to keep the door gasket from building frost. Without it the door gasket wont properly stick giving you that air tight seal.
Mar 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Stripe between fridge and freezer is extremely hot to touch
It is 100% the condensor fan motor on the back. Its not two hard to replace. Take the screws off the back panel and remove. Then locate fan. Disconnect the wires going to the motor and then unscrew the scews that mount the motor. Take the part to parts store of look it up online. Then simply remount motor and plug wires in.
Golden.
Jul 29, 2009 | Whirlpool ED2FHEXN Side by Side...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore 5126101 middle separator b/t fridge/freezer extremely hot
There are 2 or 3 things that would cause this. first make sure the condenser coils are not plugged with dust (vacumn or blow them out) next check to make sure the fan that cools these coils is running, (this is the most likely problem). if both of these check out ok then you would need to check to make sure your interior lights ar going off when the doors are closed as these will add extra heat and cause the center rails to run hot. last and most uncommon would be a freon system problem.
fyi there is a hot gas freon line that runs in between the doors to prevent exterior sweating. when poor or no air flow problems for the condenser coil exist it causes this area to become hotter.
One more thing. if you do determine that the condenser fan motor is bad you can put a normal house fan blowing on to the coil to help cool this area down until you can get the unit repaired.
If you need any further assistance leave me a comment here and I'll gladly get back to you. Thanks Peyton
Mar 11, 2009 | Refrigerators
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Panel between fridge and freezer extremely hot
this is happening because company used pipes inside refrigerator body, as you mentioned now its heating more than normal,. need some technician to check if there any blockage etc. otherwise less heating of body is normal.
Nov 30, 2017 | Kenmore 44103 Side by Side Refrigerator
Losing coldness in freezer and fridge. side panels near freezer door are extremely hot to the touch. bottom back of the fridge is extremely hot.
Condenser is in need of being cleaned badly or your fan motor to cool the condenser is not operating. Compressor is overheating. Removed the panel in back of the refrigerator and clean the condenser so air can freely pass over it for heat removal. Allow compressor to cool off before restarting it.
Jun 10, 2008 | Frigidaire Refrigerators
Kitchenaid Side by side refrigerator/freezer
when is the last time you cleaned the condenser coils the areas you describe are supposed to be hot there is a loop there to keep the door gaskets dry but should not be too hot pull the fridge out check to see if the fan is running on the compressor then unplug the unit and clean the coils the only other thin that will make it super hot if there is a leak in the low side of the system and has drawn air in see if cleaning the coils fixes it first and we will go from there
Feb 13, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
163 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
