Question about E-Machines eMachines Monitor E15T4
Monitor display my monitor comes on for a short period and goes dip
    Brigadier General:
  • 6,966 Answers
Your posted description indicates possibly a heating problem inside the monitor. Often these are capacitors that have blistered and are no longer effective in holding an electrical charge. It is also possible that some solder joints are getting loose after a while and looses their contacts to the component pins. Still, it is also possible that there some wire connectors that are loose and looses entirely their connection when reaching a certain temperature.
All of the above would require that you be familiar and knowledgeable with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable, perhaps it may be to your advantage to seek the services of a qualified professional or even a service center.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Posted on Feb 07, 2008
Samsung monitor goes blank after working perfectly for a period of time.
Have you checked monitor settings Carl? Some are set to sleep after a certain period of time. Mine was set to sleep after 1 hour (unknown to me) until I reset it. =)
Dec 06, 2015 | Samsung 933BW 19 inch Monitor
Why is my pc monitor showing a blank screen after start up?
Sounds like the power supply in the monitor is gone. It's cheaper to replace than repa
Jul 29, 2014 | IBM ThinkVision Computers & Internet
Screen display only comes on for a second then goes black when pc input from vga port.
Try it on another PC, check all the pins on the VGA cable first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Princeton Digital VL1916 19" LCD Monitor
Monitor goes black
You may have failed backlight inverter circuits, power supply, lamp assemblies. First place to look will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 20, 2010 | Proview PL926WBi 19" LCD Monitor
My LCD monitor is blinking green but no display is coming, some days back after blinking 15-20 minute display comes. But now display not come
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 09, 2010 | Dell UltraSharp 1701FP 17" LCD Monitor
No display, when I hit power, the light blinks and its off.
Look at the power supply first, look for burnt parts, bad capacitors, etc.
Please post back what you find
Nov 26, 2009 | BenQ FP71G 17" LCD Monitor
My monitor goes to sleep all the time it is very frustrating
Go into Control Panel, then to Power Options.
In XP, you see a selection for Turn Off Monitor. Adjust that setting as desired.
In Vista, you'll see Choose when to turn off display on the left side. Choose that option and select the desired time setting to turn the display off.
Oct 03, 2009 | HP w1907 LCD Monitor
Screen goes blank
abandoned problem for now. will look for inverter board or parts from another monitor
May 12, 2009 | ViewSonic 22" FLAT SCREEN CRT BLACK...
E-Machines eMachines Monitor E15T4 Logo
43 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
