Question about NEC DTU 8D-2 Corded Phone
I can't get the voicemail button to work
From main phone, I went to voicemail mgr and selected the extension number then made the box "new". When I go to the new phone, I tried spkr 43 spkr (inserting our vm extension 399). I can't get the voicemail button on that phone to work. Have tried other new phones and no luck. What am I doing wrong?
  • heffron Feb 12, 2008
    You are my hero. Thank you.
  • 43 Answers
You are describing two different things. The "speaker 43" is the default code for Busy/No Anser Set. The correct syntax should be Speaker - 43 - 399 - Speaker. That should set CFWD B/NA to VM. Next, if you have a button programmed to call VM, it is probably a speed-dial or one-touch button. It would have to be programmed to dial 399. If that is not working, try calling VM (399) and make sure you can get into the box that way. If that works, but the button does not, press the Feature Key and the button for VM. It should display what is programmed for that button. If it needs to be changed to call VM, the syntax is: Feature - Redial - the button to program - "1" - "399" - Feature.
Posted on Feb 12, 2008
My Nortel phone NT8B27JAAE6 has locked me out of the voicemail. Can you tell me how to reset it???? Thanks Agatha
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the line you are using.
May 09, 2011 | NorStar T7316E Corded Phone
I'm locked out of the voicemail feature and I can't find a way of activating a new password to pick up messages. It's a Nortel T7208 system. Has anyone any ideas?
Feature 985 will show you the extension of the phone you are using.
Feb 18, 2011 | Platinum Norstar T7208 Telephone
How to forward a call to a virtual voicemail box
With the caller on the phone, press a "Voicemail Transfer" button, then the extension number and hangup.
OR
With the caller on, press FEATURE 14, then the extension number and hangup.
May 19, 2010 | AT&T Lucent MLS-12D Phone
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Jan 08, 2009 | Panasonic KX-T7630 Corded Phone
How do I access the voicemail on A NEC SV8100 system in order to change the message?
Need to be on the programming extension. Select "VMsg", enter password, then select to "more"
Dec 24, 2008 | Lands Phones
Voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i found, helped me out
Apr 30, 2008 | NorStar M7310 Corded Phone
Resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Voicemail
From an admin phone, enter the voicemail. Then select More, Mgr, ChBox, then enter the ext# you need to reset the password on. Then choose Reset Password (Select Yes when the system asks you if want to reset the password). You can access the reset extension's voicemail by entering the default code.
Dec 27, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Unlocking the security cide to access teh mailbox?
Find out who has administrator access (usually extension 100) and use that phone, call voicemail, press "more" press "MGR" press "CHBX" listen to the voicemail which will prompt/ask you if you want to delete the security code. Say yes!
Nov 06, 2007 | NEC DTU 8D-2 Corded Phone
NEC DTU 8D-2 Corded Phone Logo
259 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
