Question about E-Machines etower 633id PC Desktop
Water spilled on my laptop computer
While it is turn on ,unfortunately a cup of water is poured to my laptop computer on its keyboard.now it is not working.when i plug the socket the battery light and the computer light are on ,but the plug light which must be turn on i off.Therefore what do u think is the possible problem of my computer.what shall i do?
Thanks
fa97
I appreciate your help
    Scholar:
  • 119 Answers
Im sorry to tell you but more than sure it is  a short circuit on your mother board.its less you can do.because it was on when it happened.if it was off..well the situation could be  better..
so,for now let it 'dry' in  a warm dry place for few days.if the problem remains the same you should go to a specialised service .theyll handdle the problem and replace the eventual damaged component..
sorry man..is less we can do in this situation..
bye
Posted on Feb 07, 2008
How do I fix a leaking Bunn Coffeemaker model NHBX-B?
This is a home model pour over. Overfilling is the most common cause of leakage as there is no plumbed in water line. You should only pour in the amount indicated on the decanter. If it is overflowing, check if you have the right decanter as someone may have used an old pot from a larger brewer. Say there was a 12 cup pot around and now you have a 10 cup brewer.
* carefully pour water to the inner fill line. You will probably see a ledge or spill off hole on the inside of the fill tank. Some units will spill out the back, others may spill back into the drip funnel. Note at what point you get near the spill level and note how much is left in the decanter. The amount left is your over flow.
* If you want more accuracy then use a measuring cup and count how many cups are needed to fill the brewer.
* Unplug any brewer that has water coming from the base. Dry up the area and drain the brewer. Dry off and let sit to completely dry out. Refill, note any leaks? If okay then plug in and brew as normal.
* still having problems? Contact your vendor for service.,
Aloha, ukeboy57
Jun 30, 2015 | Bunn NHB Coffee Maker
Tip
Spilled liquid on Keyboard!
1. Purchase plastic keyboard cover. 2. Keep coffee etc. anywhere not near keyboard.
For spill, unplug keyboard. If non sugar liquid, invert keyboard, shake or tap gently. Wipe with lent free absorbent cloth while still inverted. If soda or coffee with sugar, pour 1/4 cup of clear clean (distilled the best) water onto keyboard (yes), Then invert. Let dry a minimum of several hours still inverted. I cheat with a hairdryer on low 6-12 inches. After keyboard is completely dry (and cool). Plug in after turning computer off, restart, test all keys, including shift, option etc. If keys miss or don't work buy new keyboard and cover! Aloha, Cliff
on Sep 27, 2014 | Apple 24" iMac Desktop
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Compaq nc 6220 laptop keyboard water damaged and all keys unresponsive
We have all done it .It was a cup of tea that went over my last laptop and there was no way that I could repair it. If you have insurance cover on it specifically you may be able to claim, otherwise expensive repair.
Keyboards start around 19 pounds free postage on Amazon There are wireless ones too. Hope this helps Anna
Mar 02, 2013 | HP Compaq nc6220 Notebook
Spilled water on my asus laptop
Maybe or maybe not.They can not be opened.
Oct 23, 2012 | ASUS Computers & Internet
Juice spilled on dell laptop,the problem is when i press certain keys 3 or 4 letters apear,it is the same with a new keyboard
If that happens with a new keyboard then the mother board is faulty and a replacement laptop is on the horizon. What happens with an external (USB) keyboard?
Hope this helps.
Feb 03, 2011 | Dell Inspiron 1525 Laptop
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
Coffee got spilled on my laptop keyboard. The laptop seems to work fine all except for the keyboard. When I push the keys, something different shows on the screen other than the letter I pushed. Like if I...
How to Fix Spilt Liquid on bda25ce.jpg?
You accidentally knocked fruit drink or a late night glass of milk on your laptop or your child spilled a good portion of milk directly into your keyboard. You hear a popping noise, the screen goes black. Water by itself is not as bad as milk or juice, both of which are corrosive/acidic, or coffee, tea, soda, etc.
First and most important -Calm Down and unplug the computer from its power source.
Disconnect it from the power cord and remove the battery. If needs, please remove the keyboard. The old adage - Water and Electricity don't mix - is quite true. For your laptop spilled water, let your laptop dry. Do not attempt to turn on the computer for at least 72 hours. Let it sit in a cool, dry place. If you disassembled the laptop, reassemble it after 72 hours have passed.
Oct 13, 2010 | Computers & Internet
I spilled coffee on the key board and need to replace it. The key board appears to be sealed in with a plastic surround. How do i get the key board out? It is an E-system 3213Intel celeron. Yours hopefully...
Take the keyboard and run water over it and take it apart and let the component dry out (while it is not connected to the computer).
I had a mechanic tell me that this is what he did to a keyboard that was part of an automobile engine analysis Bear Ace machine at Sears.
He said that someone spilled a cup of coffee on it and it wouldn't work.
Good luck on this repair of a coffee stained keyboard.
Jul 20, 2010 | Gateway Computers & Internet
I spilled tea on my packard bell easynote
Two things to check.
Open the laptop up and re-connect the keyboard connection. It has a locking mechanism so be sure to unlock that first. Also when you're doing that you can see if there's any water (tea) still in there to dry off.
If that doesn't work, then plug in an external keyboard mate, cause the only other way to fix this is to replace the keyboard, the parts to open up the laptop keyboard itself are intricate and it's much too compicated, plus I've never done that (Seeing as that it's all glued together).
Hope this helps, be sure to rate!
Jan 03, 2009 | Toshiba Satellite M45-S165 Notebook
E-Machines etower 633id PC Desktop Logo
239 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
