Question about LaCie (300728U) 250 GB Hard Drive
Drive Full After Backing-Up Just Under 4gb of Files
I connected my new Lacie 250gb hard drive and began to perform a backup of my Dell XP-400 PC. I have approx. 19gb of files to backup but got a disk full message after a little under 4gb was copied. Why would a 250gb capacity drive fill up after copying less than 4gb? Did I miss a step? The drive was recommended by a Dell technician who thought the capacity drive I selected would more than meet my needs (by far).
  • 77 Answers
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Posted on Feb 07, 2008
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Mar 19, 2009 | E-Machines eMachines Desktop PC
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Hello, I have a LaCie 250GB Hard Drive and it´s not being recognized by my PC. I have Windows XP SP3. What should I do?
All brand-new hard drives are sold unformatted and thus don't show up in Windows until they've gone through the formatting process. To get up and running, connect the drive, boot your PC, and at the Windows desktop right-click the My Computer icon and select Manage. Click Disk Management in the left-hand tree, and every drive connected to your system will show up. Simply right-click your new drive and select New Partition. Then follow the steps to get your drive up and running.
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Error copying file or folder
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Feb 11, 2008 | Buffalo Technology 250GB USB SATA 2.0 HD...
Lacie 250GB external HD (Error Code - 1309),
For systems prior to OS X; error -1309 fileBoundsErr: file's EOF offset mark or size is too big If your disk is formated as HFS rather than HFS+, you can get this error. For OS X; Error 1309 is a file bounds error. In other words there is some discrepancy with the file's size or end-of-file marker, or some variation on this. This sounds like a read error not a write one i.e the problem lies with the original file. Now, you may ask, "How do I make it HFS+?"... You would have to reformat the drive to change the formatting to HFS+ (Extended). Backup anything you can't replace on that disk, then use Disk Utility in your Utility folder to reformat the disk. Use Extended formating option.
Mar 27, 2007 | LaCie d2 Extreme 250GB External with...
Hard drive not mounting
If you still have the files on your pc and just use the drive as a backup, then there is nothing lost yet, and no need to recover, just return to retailer. But if there is any sign of life, check; Right Click My Computer>Properties>Device Manager>Hardware,see if your Drive is in the list, if not, on top right there is an icon for scan for new hardware. See if your PC can find your drive, if not return it.
Nov 03, 2006 | LaCie d2 Extreme 250GB External with...
LaCie (300728U) 250 GB Hard Drive Logo
247 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
