System restore my system restore was disabled. it started when i got unfected with the destrukto virus. the virus disabled my task manager, system restore and run. i got rid of the destrukto using the noobkiller and my task manger and run were restored. But the system restore is still disabled. And it doesn't appear on the sytem property box. i was told that if sys restore doesn't appear on the system property, that means i don't have an admin acount. How come? I own the laptop! please help!
    Genius:
  • 1,142 Answers
Start the System Control Panel applet. Select the System Restore tab. Clear the "Turn off System Restore on all drives" check box to enable System Restore, or select this check box to disable System Restore. Click OK.
An alternative to the usual method of enabling and disabling Windows XP's System Restore feature is to use the registry. To use this alternative, perform the following steps: Start the registry editor (regedit.exe).
Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore.
If a "DisableSR" value doesn't exist, go to the Edit menu, select New, DWORD value, and create the value.
Set the value to 1 to disable System Restore or 0 to enable System Restore.
Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\sr to prevent the System Restore service from starting.
Double-click Start, and set the value to 4 to stop the service from starting or to 0 for normal startup. Close the registry editor.
Posted on Feb 07, 2008
    Problem Solver:
  • 8 Answers
The best solution for U is format the c partition of ur system or get an original Quickheal antivirus 2008 which will help u
DATAMNGR COORDINATOR HAS ENCOUNTERED
Depending on which level of risk of the Pup.datamngr virus has infiltrated your PC, you might find it is hard to get rid of this sophisticated worm. Some people have successfully cleaned out the stubborn worm, but since one of the primary functions of this virus is to disable security programs,so the method of using anti-virus program is not always a foolproof approach.
Please follow these steps to get rid of Pup.datamngr virus manually:
Step 1: Press CTRL+ALT+DEL or CTRL+SHIFT+ESC. Open the Windows Task Manager.
If that didn't work, try another way. Press the Start button and click on the Run option. This will start the Run tool. Type in taskmgr and press OK. This should start the Windows Task Manager
Step 2: Within the Windows Task Manager click on the Processes tab. Find the process by name. random.exe. Then scroll the list to find required process. Select it with your mouse or keyboard and click on the End Process button. This will kill the process.
Step 3: Delete malicious registry entries.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\random
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\run\random
Step 4: Remove malicious files of Pup.datamngr virus
C:\windows\system32\services.exe
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr)
C:\Program Files\Search Results Toolbar\Datamngr\SRTOOL~1\searchresultsDx.dll (PUP.Datamngr)
Sep 11, 2013 | Microsoft XP Computers & Internet
Had a virus got rid off it but now screen is white and cannot do anything with it
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Task Manager is disabled. We want to enable the Task manager in my computer
If it (Task Manager) was not disabled by the Administrator (in case your computer is on a network), you can easily enable the it. But you need to know that this could also be done by viruses. As we know, this issue is often created by virus. So I would suggest you to run a full system Scan using an updated antivirus (for this problem, I would recommend you to use Avira free antivirus, you can download it from avirafreeantivirus).
To enable the Task Manager, follow the below instructions:
Click “Start” > “Run” and type in “gpedit.msc” (without qoutes) and press Enter.
Group Policy Editor window will open, once it’s opened, follow the steps by clicking your mouse as labeled here (sequence 1, 2.....):
Once you double click the "Remove Task Manager", another window will pop up, click your mouse as labelled below (Sequence..):
After you are done, close the Group Policy Editor and go check your task manager, hurray, it's working.
But that's the end, the problem may return if your system is infected by virus, so don’t forget to run a Full System Virus Scan using an updated antivirus.
Good luck.
Thanks for using FixYa.
Aug 11, 2010 | Computers & Internet
Computer
Well, your problem seems to be due to a virus attack. Certain virus disable your task manager. To solve this, scan your computer with a good antivirus software and remove the virus. But in most cases you won't be able to restore the task manager with the antivirus application. So the best method is to backup your documents on the the drive where OS is installed and reinstall your OS.
Jan 05, 2009 | Computers & Internet
In system Taskmanager is in diable how to sovle ?
this happens due to spy ware / virus
so you need to get rid off them,
To active your task manager:
Click Start
• Click Run
• Enter gpedit.msc in the Open box and click OK
• In the Group Policy settings window
o Select User Configuration
o Select Administrative Templates
o Select System
o Select Ctrl+Alt+Delete options
o Select Remove Task Manager
o Double-click the Remove Task Manager option
and choose Not configured option then click on apply to ok.
if even you are not able access your Run command then follow the following option:
Go to the this web site
http://www.kellys-korner-xp.com/xp_tweaks.htm
scroll down until you see 113 number
one you reach on this number click on "Enable" to the task manager
and save it on your deskto
you are done with downloading then double click on it and follow the given instruction on displayed pane.
now you should be good.
Note: you must run full virus(up-to-date one) scan once you enable yoru taks manager because this happens due to virus, maleware, spy ware and trajons.
Thanks
Dec 26, 2008 | Computers & Internet
Task manager
looks like the work of a virus..download task manager fix from http://www.taskmanagerfix.com/ and use..dont forget to do a full virus scan after turning off system restore..hope it helps
Oct 28, 2008 | Sony VAIO Digital Studio PCV-RZ22G PC...
Hinhem
Please Restart your computer and get to 'safemode'.you can do this by pressing F8 before your window starts up then selecting safe mode from the options available.When u get into the safe mode,there will be a pop up menu asking u something,click 'no' button and then click 'restore my computer to a previous state'.you will be shown a calender,you should click the date before your friend gave you the virus,and then start the system restore.after sometime your computer will restart and everything will be all right.
Oct 27, 2008 | Microsoft Windows XP Professional With...
Task manager
If you are certain that you are logged on as administrator or has administrator privileges, then a virus is preventing your opening of the Task Manager. Additionally, the same virus is likewise preventing access to the Folder Option and the MSCONFIG function.
Of course the correct solution would be to run a full deep virus scan and delete detected ones. You can also try running RRT.exe to force access to the above functions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 29, 2008 | Microsoft Windows XP Professional
Disabled task manager
try selecting the run option under the start menu. type in "gpedit.msc" and go to User Configuration, then Administrative Templates, next System, and next Ctrl+Alt+Deleve Options. Choose Remove Task Manager and double click the Remove Task Manager option. Disable this, and restart the computer. a shortcut for the task manager is Ctrl+Shift+Esc.
Jan 09, 2008 | Computers & Internet
Serious TaskManager Problem!!
Task Manager can be disabled by 2 main ways..
[1] Either there is a virus on your machine--
[2]Or It was manually disabled.
--The 1st solution is to get an anti virus which is up to date and run a virus scan to delete the viruses that maybe present.
--The second solution is that on your START MENU, click on "run".
On 'run' type "gpedit.msc"..
Under the "User Configuration" , click on " Administrative Templates"..
Then you double click on "system" .Double click on "Ctrl+Alt+Del Options"... Double Click on " Remove Task Manager" and click on "Disable"... Click on "Apply" and "Ok"
Your Task Manager should now work !!!
Jan 03, 2008 | Computers & Internet
Computers & Internet Logo
272 people viewed this question
David Payne
David Payne
