Question about Buffalo Technology (WYR-G54) Router
Routers sometimes i can connect wirelessly then sometimes it says i cant connect to the net or it cant display the page....i have an acer4315 laptop and buffalo router and virgin broadband.....when it says i cant connect i look at the signal strength and it always says 100% ....please help as new to the net.....thanks
    Problem Solver:
  • 21 Answers
If you know how to access the configuration page of your router, change your channel and check also your distance from the router itself.
Posted on Feb 09, 2008
You may simply have incompatibility issues, there now where near as problimatic as they used too but still exists. First off make sure that when you try to connect that you have the right security settings, (if used the disk from the router or had somebody install it you should have written it down). When configuring your router always do it with a hard wire connected so as you don't drop yourself every time you change a wireless setting.
Take your laptop to a free wifi hotspot as way to make sure that your wireless card actually works. But if you can see your network it sounds more like a security setting issue.
Posted on Feb 08, 2008
Laptop cant connect to internet
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Apr 06, 2010 | Linksys Wireless-G Broadband Router
Our wireless net work comes up but we cant connect to it why?we have a wireless g wgr614v9 router and we cant log on to it with the passphrase
The Netgear router needs the wireless settings configured i.e SSID, WPA encryption etc and the wireless card in the laptop/computer needs to be configured with the router's wireless settings for the laptop/computer to connect with the Netgear wireless router. Pleas click on this link and follow my instructions to secure your wireless network, configure the wireless router's settings and configure the wireless card in the laptop/computer :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 21, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Cant get computer to take security key number
what is the Operating system on the laptop ?
Sometimes on Windows 7 it will not accept the network key?
You will need rto change the security type to WPA
Change the wireless channel to 6.
try to change the SSID also.
then try to connect to the new network and see if that works.
You will need to open the set up page of the router.
click here for more info about routers and network
Jan 30, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I can not browse using wireless.what can i do .i have instailled the drivers and yet is not working. my wifi is not coming up. if i use lan i will browse. the product is acer4315. pls help
First check your wi fi network adpater driver installed and working fine also check it is enabled.
Turn on wi fi switch on your laptop.
Check that you get signal from router very good strength.
you can access your router with defaults link.
http://192.168.1.1
or http://192.168.0.1
connect your router to computer with ethenret cable then access above link
then check in router configuration that wireless is enabled .
If it ask for user enter "admin" and password as "admin" or blank or "password"
Aug 25, 2009 | Acer Aspire 5100 Notebook
I have lnksys160n first when ran the start up disk I was no longer able to connect to my existing net,web page could not be displayed,so after acouple of ours on the phone with cisco rep,Igot online but...
Please email me for my number at jason.semon @ gmail.com
This is almost impossible to explain in a message, but I can secure your network in a short time.
As far as the issue of being 30-40 ft apart from the router, this depends on the both the WRT160n and the Wireless NIC in the laptop. Some are better than others. The NIC in the Toshiba may not be all that great. I am not familiar with these.
Apr 02, 2009 | Linksys WRT160N Wireless Router
Cant connect to net in other loc
i sort of have the same problem. at my house my linksyys always asks for a passcode. the passcode is either the wep key or the wpa key. look around the web to see if you can find where to find the wep or wpa key cuz i still havent found mine
Jan 25, 2009 | Apple iPod touch
Router
I use a second wireless card for just such issues.
the internal cards antenna is weak.
toshiba seem to be the worst about this to me.
Feb 03, 2008 | Buffalo Technology (WYR-G54) Router
My net is airtel broadband but it connected through liksys router
You might be getting intermittent connection. What is the exact model and version of your router? check your firmware. It might need to be upgraded. =)
Jan 19, 2008 | Linksys Wireless-G WRT54G Router
Wireless connection works and then disconnects itself
look for a program on the web called Net Stumbler
It should be here http://www.stumbler.net/
That will show the signal level from your router.
I have seen this before and it could be several different problems
1. Someone else on your channel
2. Burned out ant or output section in the router
3. Broken Ant wire in laptop
Hope this helps
Jan 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Buffalo Technology (WYR-G54) Router Logo
80 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
