Question about HP Color LaserJet 2600n Printer
Can't color balance 2605
Hiya - just boughta 2605 for printing out DTP layouts. Cant get print density settings right. no matter the setting, seems too much magenta in pictures, and not enough magenta in flat coulours - a 20% magenta 20% cycan mix looks totally cyan, Please help. Anyone have "optimum" print density (slider) settings for a new 2605? Thanks!
  • DesireeP Feb 10, 2008
    Thanks for the help -- seems the problem all along was the printer driver. 2605 default does not install the postscript driver. Since installing the PS driver, colours are more "true". I had to discover this for myself though, 100 pages and 20% use of toner cartridge later! Wish HP was more helpful with colour match problems.
    Genius:
  • 3,587 Answers
Well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Posted on Feb 07, 2008
C390
[C390] Auto-toner sensor-C abnormality (Cyan)
<Color toner low density>
When you check the printing status to find out that the color printing ratio isless than 5%, color toner low density might be the cause.
Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged number of sheets setting".
If the color printing ratio is 5% or more, check the following.
(1) Is the developer unit installed properly?
(2) Check if the connector CN340 on the LGC board isdisconnected from the auto toner sensor or the harnesses are open circuited. Correct if necessary.
(3) Check if there is any foreign matter such as toner in the drawer connector of the equipment and fuser unit or the connector of the auto toner sensor. Remove if there is and reconnect it.
(4) Service or replace the auto-toner sensor.
Apr 04, 2014 | Toshiba E Studio 2330C
I see where to change color density settings in thick paper. Can I do this for plain paper? (Normal printing is too dark.)
The only changes you can make are in the printer preferences menu, so if you have lightened it up there you have made the only adjustment allowed or provided for.
Jan 20, 2012 | Konica Minolta Bizhub c203 Copier
MY HP COLOR LASERJET 2605 CANT PRINT.IT SAYS PRINTING DOCUMENT BUT IT CANT PICK PAPER
uninstall the printer then reinstall it like its a new printer and it should work
Mar 03, 2011 | Office Equipment & Supplies
My phaser 740 has print that flakes off when you print pictures with real dark areas. I assume it needs more fuser heat or less paper speed. The problem is I can' t figure out how to adjust either of these...
Recalibrate the colors. Flaking is sometimes caused by more ink/toner than can be fused to the media. There's a limit for the total amount of ink/toner. Yours may be set too high.
You'll need a copy of the Printer's User's Guide (also Downloadable from Xerox.com)
Controlling Color Density
When colors look faded, adjust the toner color density to extend the life of the components.
Print and use the Color Reference Page 1 In the printer's front panel, scroll to Calibrate Colors,
press Menu and print the Color Reference Page. 2 Compare the Color Reference Page to the Color Density
Samples on page 39. Make a note of the value (-10 to +10) for each color that most closely matches the samples.
3 Adjust the density for each color: Enter the value noted in Step 2 in the Calibrate Colors menu, under Adjust Each Color.
? Decrease color density: Press . ? Increase color density: Press --->.
4 Reprint the Color Reference Page; check your adjustments
Dec 09, 2010 | Tektronix Phaser 740P Laser Printer
My printer prints fine, but how can I make it print darker. It seems to have gotten much lighter and the ink is relatively new.
There should be a button on the top that says lighter/darker, move it 2 clicks to the right for more ink to be used..... please let me know if there is anything else you need, happy to help! Guy :)
Sep 23, 2010 | HP LaserJet 3050 All-In-One Printer
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
Right color balance standard print setting, but wrong in high rez
Hai,
before giving the print command clear the previous notepad given by the printer by manul and restrat your printer and give print command
Dec 25, 2008 | Canon i9100 InkJet Photo Printer
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Color Laserjet 3500 Problem
If you are sure the diagnostics show the colours correctly, one thing I would look at is to see if it had a colour profile set up for it.Don't know whether this printer normally has, if it has not I would suggest reinstalling the driver. To check - Start/Printers & Faxes/ Rt click on printer then properties, look under Colour management tab. Pete
May 25, 2006 | HP Color LaserJet 3500 Printer
HP Color LaserJet 2600n Printer Logo
283 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
