Question about Compaq (480082-001) ( 480082-001 ) Power Supply
Testing of compaq server psu
Model ps 7331 1c
  • 123 Answers
Please provide more information... are you missing 5/12 volt supply or what? cheers
Posted on Feb 19, 2008
Compaq 1930nx no power
May be the PSU. This PC has a few miles on it ,right? I had a HP/Compaq SR1120nx when the PSU when out it would try to start and immediately shut down. Over and over. A PSU is not that expensive. Be sure to get the same type ATX connectors. Verify it is a ATX. Mine was 400w for under $50.00. I uped the power from 250w to 400w, I had added Graphic card, sound card, wi-fi card.
Nov 18, 2012 | HP Compaq Presario SR1930NX PC Desktop
Hi, I have a Compaq PSU (PN: 230822-001) from a HP Proliant server. I am try to test the output of the unit but need to 'enable' it using the pins on the back... Do you have any information...
OUTSIDE of a redundant PSU - The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue.. Many computer shops will test for free.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Sep 16, 2011 | HP (230822-001) (230822001) Power Supply
Server is not powering on
Switch PSU between bays Use spare PSU
If server is still not working PSU backplane needs to be replaced. IS spare PSU sovles the issue, then it was a faulty PSU
Feb 26, 2011 | HP Compaq ProLiant ML350 G5 Server
The server comes on for a mili second and recycles power does the same repeaditly, it was working fine all of a sudden poof it turns off no warning, i turned the swich off, and then back on it came on,...
The PSU , if it sees outputs dead or overloaded they all do that.
test the PSU unplugged with the power on pin jumpered
if voltages all pass tests and it stays on, it can be ok.
then find who on the MOBO end is shorted.
by removing things , like all HDD< and DVD or all things
but CPU.
even pull ram. all things in electronics can in fact short.
Sep 04, 2017 | Compaq ProLiant 5500 Server
Compaq dl380 g1 - 1611 Power Supply 1 Fan Failure Detected
it only ur fan problem which one of the four fan or two ,might be stuck or jammed which starts after of couple of restarts, so i sugest u to check the fans when in operation
good day
Jun 01, 2010 | HP Compaq Proliant DL380 G1 Server
Power edge 1800 bought october 2006. It does have a DELL 650 Watt non-redundant power supply, type nr. PS-5651-1. Can I replace it with a standard ATX power supply, or is the connector not standard wired...
Dell uses proprietary psu's. You will need to contact them for replacement psu or find a supplier that makes psu's that can be used as a Dell replacement. Hope this helps.
Jul 07, 2009 | Dell PowerEdge 1800 Server
Compaq (480082-001) (&#160;480082-001&#160;) Power Supply Logo
362 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
